Mugabetown - Whoretownin' At It's Worst.
Not sure first time its ever done it. Then later it fluttered between 3000-3500 with no actual rev loss to motor. :/ Strange. Didn't play up at happy laps.
dry joints in the tacho can do it.
if you are decent at soldering, redo all the solder joints in the tacho.
Cleaning the injectors could just add to the problem.. The ECU is doing it because another sensor is out.. have you reset the ECU, clean AFM and make sure you don't have a air leak or atmosphere bov..
Could be fuel reg?
ECU has been reset, AFM cleaned just before that, stock return BOV. Can't hear any air leaks. Ran a error check on the ecu it came up thst everything was fine.
Afternoon whores...the SS went to the repairers today...lets see how long they take to give me an incorrectly repaired car back.
5 weeks. Will sit at quoters for 2 weeks for the assessor to look at.
love the positive approach their Mikie.
Hopefully, it will be fixed soon. Just keep communicating with them.
I'm yet to find someone who has had a car repaired by them and be happy with it and not be f**ked around, my hopes that it would be different for me were dashed when they initially sent me to a place that doesn't do imports...
^this. If you don't ring them they will not contact you. The only time I got any updates on my repairs was when I rang just car and got the repairers number.
Greg, I called that dude today about white rb30 - he sounded fully sic and tells me it's not modded, but genuine Tomei rb30 cam, valves, springs and retainers. He said High Octane got custom Tomei stuff for builder.
So what really happened is they bought a wade cam and a set of letter punches, stamped Tomei on the cam and charged him 4 times the price they bought the wade cam for, because he is a silly kebab.
Haha thanks. Just waiting on today to see if the skyline is ready. I owe zac so much for working on it
You still owe him for that maltesers incident, stop being slack.
Luckily I worked 500m from the assessors, they got to see me everyday as my patience wore thin
  • Like 1
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
