Mugabetown - Whoretownin' At It's Worst.
That was last camp apparently there was like 6 in a pile
There in the scouts community but we are in what's called rovers.
Under us is venturers and they are 14-18
Then below that is scouts
Hey everyone :)
howdy :action-smiley-069:
I'm more shocked that 18-24 year olds are still in scouts?
this
And I'm just sitting here 22yrs old and not having any sex.
:domokun:
Sounds like not being in scouts was a mistake.
and this.
Understatement, and well done to em I say......dunno if i'll make it after the charity cruise.
I can see mass defect stations setup all around dreamworld that day.....totally random of coarse
If this is as big as they say and i believe it will be this will be up there with "jafs cruise in adlaide" 1000 plus cars
and thus totally worth a defect
Edited by ibrox90
Nothing is worth a defect.
Not even especially reach arounds from Tony.
You love it.
Also, planning a Golf Day. Just casually with a few guys playing ambrose. Open to suggestions on locations and dates. At this stage, thinking 22nd or so. Midday/1pm tee off.
Non-negotiables are:
Beer
Buggies
Scott, any recommendations?
You love it.
Beer
Buggies
Why not stroke play? :P
1.5-2k with all interior don't care about engine or gearbox have one lined up
$2k? With all the interior? For a rolling shell?
Seriously?!
Mikes selling a z32 rolling shell. Ask him if he'd part with it for $2k.
I don't care if the paints shit and there isn't an engine and gearbox in it I just want a cheap straight shell to have for project I have an rb25det engine lined up for a rebuild
Rolling shell for 2k is a lot man you can get a 31 in close to roadworthy for 2k
1k for rolling shell is around the right area
As I said Matt hit up all the places I told you, I also forgot about boost cruising
They sell rolling shells like no tomorrow
Especially the 32 and 33's
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
