Mugabetown - Whoretownin' At It's Worst.
Zane and I will take that as a compliment...
its how it was meant.
None of us who were at the really pointy end go and run at Texi any more. The good ol' days are gone!!!
Planning once my second r33 is done to get Sarah and i down to the motorkhanas in Canberra, we checked them out earlier and its some real competition!
Hi Mel
Hi Ants!!! :action-smiley-069:
Hi Mel! Which team would you bat for?
Queensland... I never liked living in NSW or ACT...
If you want competition go to the Sydney ones.
going to try and spray a rear bar over xmas :-/
Ants is my inspiration. whites a bit easier though.
I figure ill try whats the worst that can happen .
i f**k it..... then i rub it back and go again
  • Like 1
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
