Mugabetown - Whoretownin' At It's Worst.
#@Sneaky Pete
Nah it's cammed bro, big time camed
Who is this Sneaky Pete fellow? My name has incorrect spelling and i'm proud of it.
Also... say what?
Hey all. Back at work today....
Sucks
Slow morning is slow
Double sucks
(does that mean... it blows?)
Shouldnt take you long with the right foot to the floor!
it will though, he needs to stop for fuel all the time :P he had to twice for the charity cruise....
or has that fueling issue being resolved ??
Edited by ibrox90
Fueling issue is fixed, kinda. I'm getting about 15l/100 but with this cam that's fine :)
Holy shit balls!
How are you getting so bad on the freeway?!
Standard commos with a cam and tune will see 30% better fuel efficiency!
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
