Mugabetown - Whoretownin' At It's Worst.
Exemption had to have power to weight and now they changed it to power at the flywheel, to weight
What a bunch of tards!
Tell them to put the car on a chassis dyno and use this conversion calculator
http://khetan.gajjar.co.za/cars/calcs/PowerConversionCalculator.htm
Exactly what I thought, I'll play there game and they will more than likely throw me another curveball, but either way I will still have the car, wheat her I can drive it untill next year or not is the issue
http://www.support.transport.qld.gov.au/qt/formsdat.nsf/forms/QF4467/$file/F4467_CFD.pdf
I don't beleive you need a dyno. Clearly it says in column 2 of page 1, that you need a spec sheet from the manufacturer OR a dyno.
http://www.qld.gov.au/transport/licensing/driver-licensing/applying/provisional/restrictions/index.html
Edited by MagicMikeZ32
This Zac, under manufactures specs a 33 GTST has a power to weight of 126kw/ton.
Supporting person - GP - Because you will suffer significant mental trauma if you have to drive a NA Auto R33 :P
This is one of the most truthful things I think I've ever seen Tony type :P
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
