Mugabetown - Whoretownin' At It's Worst.
Exemption had to have power to weight and now they changed it to power at the flywheel, to weight
What a bunch of tards!
Tell them to put the car on a chassis dyno and use this conversion calculator
http://khetan.gajjar.co.za/cars/calcs/PowerConversionCalculator.htm
Exactly what I thought, I'll play there game and they will more than likely throw me another curveball, but either way I will still have the car, wheat her I can drive it untill next year or not is the issue
http://www.support.transport.qld.gov.au/qt/formsdat.nsf/forms/QF4467/$file/F4467_CFD.pdf
I don't beleive you need a dyno. Clearly it says in column 2 of page 1, that you need a spec sheet from the manufacturer OR a dyno.
http://www.qld.gov.au/transport/licensing/driver-licensing/applying/provisional/restrictions/index.html
Edited by MagicMikeZ32
This Zac, under manufactures specs a 33 GTST has a power to weight of 126kw/ton.
Supporting person - GP - Because you will suffer significant mental trauma if you have to drive a NA Auto R33 :P
This is one of the most truthful things I think I've ever seen Tony type :P
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
