Mugabetown - Whoretownin' At It's Worst.
Exemption had to have power to weight and now they changed it to power at the flywheel, to weight
What a bunch of tards!
Tell them to put the car on a chassis dyno and use this conversion calculator
http://khetan.gajjar.co.za/cars/calcs/PowerConversionCalculator.htm
Exactly what I thought, I'll play there game and they will more than likely throw me another curveball, but either way I will still have the car, wheat her I can drive it untill next year or not is the issue
http://www.support.transport.qld.gov.au/qt/formsdat.nsf/forms/QF4467/$file/F4467_CFD.pdf
I don't beleive you need a dyno. Clearly it says in column 2 of page 1, that you need a spec sheet from the manufacturer OR a dyno.
http://www.qld.gov.au/transport/licensing/driver-licensing/applying/provisional/restrictions/index.html
Edited by MagicMikeZ32
This Zac, under manufactures specs a 33 GTST has a power to weight of 126kw/ton.
Supporting person - GP - Because you will suffer significant mental trauma if you have to drive a NA Auto R33 :P
This is one of the most truthful things I think I've ever seen Tony type :P
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
