cowdy Posted April 29, 2014 Share Posted April 29, 2014 FUARK TRANSPORT!!!! They want me to take my engine back out for a dyno!!! :@ Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7268861 Share on other sites More sharing options...
Ants Posted April 29, 2014 Share Posted April 29, 2014 FUARK TRANSPORT!!!! They want me to take my engine back out for a dyno!!! :@ why? Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7268865 Share on other sites More sharing options...
cowdy Posted April 29, 2014 Share Posted April 29, 2014 Exemption had to have power to weight and now they changed it to power at the flywheel, to weight Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7268900 Share on other sites More sharing options...
Ants Posted April 29, 2014 Share Posted April 29, 2014 Exemption had to have power to weight and now they changed it to power at the flywheel, to weight What a bunch of tards! Tell them to put the car on a chassis dyno and use this conversion calculator http://khetan.gajjar.co.za/cars/calcs/PowerConversionCalculator.htm Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7268918 Share on other sites More sharing options...
Bunta Posted April 29, 2014 Share Posted April 29, 2014 Thats annoying and a bit silly, but if you want to have the benefit of an exemption to a law I guess you have to play the game. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7268942 Share on other sites More sharing options...
cowdy Posted April 29, 2014 Share Posted April 29, 2014 Exactly what I thought, I'll play there game and they will more than likely throw me another curveball, but either way I will still have the car, wheat her I can drive it untill next year or not is the issue Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7268979 Share on other sites More sharing options...
MagicMikeZ32 Posted April 29, 2014 Share Posted April 29, 2014 (edited) http://www.support.transport.qld.gov.au/qt/formsdat.nsf/forms/QF4467/$file/F4467_CFD.pdf I don't beleive you need a dyno. Clearly it says in column 2 of page 1, that you need a spec sheet from the manufacturer OR a dyno. http://www.qld.gov.au/transport/licensing/driver-licensing/applying/provisional/restrictions/index.html Edited April 29, 2014 by MagicMikeZ32 Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7268987 Share on other sites More sharing options...
t5iv Posted April 29, 2014 Author Share Posted April 29, 2014 Supporting person - GP - Because you will suffer significant mental trauma if you have to drive a NA Auto R33 Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269011 Share on other sites More sharing options...
Cadmoon Posted April 29, 2014 Share Posted April 29, 2014 http://www.support.transport.qld.gov.au/qt/formsdat.nsf/forms/QF4467/$file/F4467_CFD.pdf I don't beleive you need a dyno. Clearly it says in column 2 of page 1, that you need a spec sheet from the manufacturer OR a dyno. http://www.qld.gov.au/transport/licensing/driver-licensing/applying/provisional/restrictions/index.html This Zac, under manufactures specs a 33 GTST has a power to weight of 126kw/ton. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269059 Share on other sites More sharing options...
t5iv Posted April 29, 2014 Author Share Posted April 29, 2014 This Zac, under manufactures specs a 33 GTST has a power to weight of 126kw/ton. Doesn't he want to disprove that it's 126/ton? Isn't the limit 120kw/ton? Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269066 Share on other sites More sharing options...
Melly Posted April 29, 2014 Share Posted April 29, 2014 I think i have found a sexier manifold than the full race ones, raw brokerage make one with a billet merge collector Awww yeahhhhhhh Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269069 Share on other sites More sharing options...
Melly Posted April 29, 2014 Share Posted April 29, 2014 Supporting person - GP - Because you will suffer significant mental trauma if you have to drive a NA Auto R33 This is one of the most truthful things I think I've ever seen Tony type Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269075 Share on other sites More sharing options...
Ants Posted April 29, 2014 Share Posted April 29, 2014 This is one of the most truthful things I think I've ever seen Tony type was that a Tony pick up line Mel? Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269079 Share on other sites More sharing options...
Melly Posted April 29, 2014 Share Posted April 29, 2014 was that a Tony pick up line Mel? Not that I am aware of...? lol Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269081 Share on other sites More sharing options...
Cadmoon Posted April 29, 2014 Share Posted April 29, 2014 Doesn't he want to disprove that it's 126/ton? Isn't the limit 120kw/ton? They upped it to 130kw/ton. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269118 Share on other sites More sharing options...
TREGTR Posted April 29, 2014 Share Posted April 29, 2014 Lol, hydraulically forming the merge collecter... it was the dump pipe. The merge collected was a billet item, same as the above manifold. awwwww Pete you watched it lol 1 Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269149 Share on other sites More sharing options...
t5iv Posted April 29, 2014 Author Share Posted April 29, 2014 They upped it to 130kw/ton. Ahh that makes sense. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269150 Share on other sites More sharing options...
sneakey pete Posted April 29, 2014 Share Posted April 29, 2014 I thought that was only nsw... Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269151 Share on other sites More sharing options...
sneakey pete Posted April 29, 2014 Share Posted April 29, 2014 awwwww Pete you watched it lol many moons ago actually. Probably need to go take a,look at progress since I last looked Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269154 Share on other sites More sharing options...
TREGTR Posted April 29, 2014 Share Posted April 29, 2014 Extreme Turbo Manifolds do amazing high mount steam pipe ones Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/823/#findComment-7269159 Share on other sites More sharing options...
