Mugabetown - Whoretownin' At It's Worst.
Where to start...
Monday afternoon, we have a script run which exports stuff into a stupid legacy forecast reporting tool. Script effed up and actually pushed info into P6 and blew away regions forecasts, to the tune of about $1B. Was at work until after 6:30 searching for what happened. No dice.
Tuesday, come in, turns out that the script had been changed, looking for a tag, so at least I knew what exactly was affected. So have to get the planner in the region to basically re do his month end update. However, Tuesday just happened to be the day that this region got their Win 7 upgrade, so planner had no P6 access to do it.
So yesterday was spent helping smash through the update with him as we are now 2 days behind EOM. At least I left work at a reasonable time.
But the bike battery died halfway home and had to get Cara to come get me (which went down well cause she is sick), so still didn't get home til after 8pm. While waiting for her I removed battery to charge it overnight.
Get her to drop me at bike this morning, chuck battery in, sweet everything works. But progressively died riding back into work, just made it to the carpark without indicators or headlights etc. Now I am stuck in city, 2.5 days behind where I need to be, needing a new battery before dark (no headlights).
Cara is real happy she has to run around and get me one and bring it into CBD.
/rant
Edited by MagicMikeZ32
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
