Mugabetown - Whoretownin' At It's Worst.
I didn't have hangover food because no hangover... But I did rage at pancake manor and get discount on foods! Took an hour to get our food this morning holy shhhiiiitttt!!!
Then came home and washed two cars and I have to work tonight... Waaaaaaaaaaaaa for working on weekends!!!
Sounds like Pancake Parlour in Civic... Except there food also tastes terrible.
And I just remembered... I have bacon, eggs, and hashbrowns ready to be cooked... MMMMmmmm... That might be a reason to finish building the BBQ...
At work living the dream.
Thought I'd take the Skyline to work for a change, went to start it and battery was dead.
Even the skyline doesnt want me to drive it
not driving it for over a month will do that Scottie
It got a 15min drive about two weeks ago. thats should be enough lol
yeah, I've gone through too many batteries like that. So whenever I know in not going to use the car for a long period of time, I just yank out the battery and recharge it if necessary when I need to use the car again
You need to put the ammeter in line and see what sort of current is being drawn, pull a few fuses until you find the circuit that drops the drain.
yeah. Il borrow my bros ammeter to solve that issue.
Ok old diff is out, new diff is in, Hicas is off (now I need a lockout kit), still need rear 5 stud hub assembly :)
I'll be selling my old lock bar this weekend...you and Mel can fight for it.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
