Mugabetown - Whoretownin' At It's Worst.
Spent 2 days on the o2 sensors.
$100 on specialty tools and a few skinned knuckles later, I have 1 o2 out FML.
Avoided engine out tho :P
Not engine out??? But I don't understand... :blink::P
Not great no, but it wasn't exactly economy driving either. I imagine quite a bit of fuel would be flowing when its developing 400hp.
Should probably put O2 sensors in to help that. Presumably there's only 1...?
wut? usually there are two 02 sensors on RB26
Strangely enough I only have one now that I could spot under my car
Found the second one on the top of my dumps, can't figure out what is going on with the plugs though. Got a pair of 3 wire ones, one flat plug one square.
edit: images
Couldn't for the life of me find another 3 plug one like the top one. Dunno where i'd be supposed to plug the second sensor into then...
Nissan made it idiot proof, the plug on the front o2 is flat and the plug on the rear o2 sensor is square
Defeated my o2s finally. Another custom tool for the collection.
now im guna need a new 22mm spanner...
I live my life a 1/4 of a 1/4 of a turn at a time
Edited by MagicMikeZ32
  • Like 1
Turbo xxxx ECU, injectors, fuel pump, FMIC, Hi flow cat (perhaps)
R34 Turbo Brodi $200
Turbo Highflow, Hypergear, $860
Braided Turbo Oil Line, Hypergear, $88
High Preasure Actuator, Hypergear, $120
ECU, Haltech Platinum Pro Plugin, $1,975
Flex Fuel Sensor, Haltech, $250
Injectors, ID1000's, $720
Fuel Pump, Nismo Intank, $385
Fuel Pressure Regulator, Nismo, $132
Highflow Cat, Venom, $250
Tuning, ???, $1,000
Total $5,980
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
