Mugabetown - Whoretownin' At It's Worst.
Spent 2 days on the o2 sensors.
$100 on specialty tools and a few skinned knuckles later, I have 1 o2 out FML.
Avoided engine out tho :P
Not engine out??? But I don't understand... :blink::P
Not great no, but it wasn't exactly economy driving either. I imagine quite a bit of fuel would be flowing when its developing 400hp.
Should probably put O2 sensors in to help that. Presumably there's only 1...?
wut? usually there are two 02 sensors on RB26
Strangely enough I only have one now that I could spot under my car
Found the second one on the top of my dumps, can't figure out what is going on with the plugs though. Got a pair of 3 wire ones, one flat plug one square.
edit: images
Couldn't for the life of me find another 3 plug one like the top one. Dunno where i'd be supposed to plug the second sensor into then...
Nissan made it idiot proof, the plug on the front o2 is flat and the plug on the rear o2 sensor is square
Defeated my o2s finally. Another custom tool for the collection.
now im guna need a new 22mm spanner...
I live my life a 1/4 of a 1/4 of a turn at a time
Edited by MagicMikeZ32
  • Like 1
Turbo xxxx ECU, injectors, fuel pump, FMIC, Hi flow cat (perhaps)
R34 Turbo Brodi $200
Turbo Highflow, Hypergear, $860
Braided Turbo Oil Line, Hypergear, $88
High Preasure Actuator, Hypergear, $120
ECU, Haltech Platinum Pro Plugin, $1,975
Flex Fuel Sensor, Haltech, $250
Injectors, ID1000's, $720
Fuel Pump, Nismo Intank, $385
Fuel Pressure Regulator, Nismo, $132
Highflow Cat, Venom, $250
Tuning, ???, $1,000
Total $5,980
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
