Mugabetown - Whoretownin' At It's Worst.
then don't go for cheap shit Pete.
Get a big brake kit like Brembo F50 with 380mm rotors or Alcon or Endless or Project Mu
Oh I also forgot AP and Willwood
and make it worth it
its a r32 weekender, not a r35 track car ants...
380 is probably to big.
those akebono kits seem reasonable, mike did you say r33 (and hence 32) and z32 stuff is interchangeable?
It sure is. I ran z32 brakes on my car for a few days while waiting for new rotors to arrive.
Correct, R33 brembos bolt straight on to Z32 (front and rear), so if R33 brembos bolt straight on to yours, all Z32 kits will fit.
Beetroot is awesome :). Not on a chicken burger though... :/
I like beetroot but my Schnitzel burger with bacon, cheese and gravy does not need beetroot :angry: They jipped me on the gravy side of things too!
And before Greg says anything, f**k the 12 week challenge today!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
