Mugabetown - Whoretownin' At It's Worst.
yeah, time to do something about that suspension
Squat is good for traction..... The Ant-Eater needs more screamer pipe!
You and I need to have a run down the straight at QR Ants Would be an interesting race with both out cars in current state
  • Like 1
yeah it would be a good match up.
But when you get your head job done I will get creamed by the Scottiemobile lol
I think for now though you would have me. I may or may not comeback top end but by then its probably over
Ants - 475hp on 22psi, rb26 awd, pump98
Scott - 450hp on 15psi, rb25/30 rwd, E85
Would be be interesting to see a highway run from 100 :yes:
ha! We need a private road
just paid over $1k to update my cabling endorsements and certifications ... stupid government ... one of the few countries in the world where you need special certification for data cabling and coax
Antisquat is good for traction ;)
Just the stocko mild steel. New car is running a mines ecu so would rather have a look at afr before I can afford nistune
Good plan, the mines ecu's I have seen for Z32 are quite agressive in the timing department, because they have far better fuel.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
