Mugabetown - Whoretownin' At It's Worst.
A bit of playing around and I am used to it now... One of the PCs was upgraded from XP, so glad that old one wasn't mine!
XP? man that's old.......although I really liked XP compared to Win 7
Now I'm on 8.1 and like it but it always takes some time to adjust
ah last day of training / certification courses today ... these things are such a waste of time ... zzzzzzz
I drew a picture yesterday.
Today I get to patch 2 cat 6 cables.
#@Hardwork
a skilled kiwi???
Imposibru!
:P
Yeah the old accounts PC was on XP! It was painful, if Zane saw me use an old PC with XP and dialup internet he would run for sure! :P
Aaaand Morning all :wave:
Slow day is slow but not slow at the same time... Busy but dragging... My desk looks like a bomb exploded and it's really frustrating me but I can't put any of it anywhere else yet :(
Teins have arrived
Inb4 queries about Sydneykid bilstien package - is on hold due to other financial commitments and current coilovers are well and truly f**ked
Zane has Tein superstreets, he hates them :yes:
they are not super streets Mel.
In fact I don't believe the Teins I have sourced are even available in Australia FTM and most suspension workshops are still selling them discontinued / shitty SS.
In fact I d'ont believe the Teins I have sourced are even available in Australia FTM and most suspension workshops are still selling them discontinued / shitty SS.
I was just sayin :)
howdy peeeps
how is everyone? i have been off the radar for a long time now for various reasons. hope to get back to normal soon. have a tumor in my skull that needs to be drilled out.
ps. anyone know much about the 300ZX Tommy Karia Edition?
howdy peeeps
Wow the Benno lives.
holy shit a tumor sorry to hear about that.
All I can say is best of luck for the op and that you get back to your good ol self asap
howdy peeeps
:O I was just thinking about you the other day, long time no see! Hope the tumour drilling goes well!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
