Mugabetown - Whoretownin' At It's Worst.
Well it ain't the tps as I sourced and installed a brand new one.
The fun begins - well have to check the voltage of attessa ECU as per service manual
I will also recheck that it is error code 21 (dodgy accountants :P can't count for crap :P )
Because if error 22 then just needs a bleed
  • Like 2
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
