Mugabetown - Whoretownin' At It's Worst.
Well the zed is nearly completely back together. Exhaust back on and everything connected. Runs on 6 and can move under it's own power.
Had to relocate the windscreen washer to the boot for airflow through drivers side side mount intercooler. Didn't have enough vac hose at home to run the plumbing but I did run all the electrics for it.
All that is left now is obviously the plumbing for the washer bottle, all the undertrays, and the intercooler ducting which is a royal PITA. Going to leave that until the tech day on sat.
Oh and I need a new wideband sensor. the one I installed is stuffed, reading 3points leaner than the other. Not 3/10th, 3 wholes.
So I was forced to replace my muffler today due to a severe rattle, my car now actually has an exhaust sound.
Picked this up second hand for $100 fully installed inc welding. It's a name brand muffler, but let's just call it a 'legnaflow'...
Awesome sauce! A step closer to skids... er... I mean Milton Maccas runs....
Sweet Baby Jesus. Looks the business.
Also, Blog update mother bitches!
http://tx5turbo.blogspot.com.au
Morning everyone!
Just a quick pop in to say hi and to let everyone know that the club emails should be working later today.
Unfortunately cmshosting and puntoitalia just flipped the switch and deleted our hosting from their servers without notification or warning.
The hosting has now been moved to a new web host and a blog/news portal with information on what events are coming up etc as well as links into these forums will be setup.
At present, any communication should be directed to [email protected]
All of the @sauqld.com email addresses should be functional later today.
Chat soon. Bout time I turn up to an event and catch up with everyone.
Cheers,
Ben.
I dislike pickles... But ham and cheese are tasty...
I followed lunch up with some popping candy and the accounts girl laughed at me :)
Now I REALLLLLY want milk but I don't have any of my milk at work :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
