Mugabetown - Whoretownin' At It's Worst.
  • 2 months later...
  • 2 months later...
  • 4 weeks later...
i got a whole $340 back! I was so lucky to not have to pay tax this year.
ps, anyone got a either a PC and Steering wheel/pedal setup or a console with steering wheel/pedal setup for sale? Doesn't have to be flash. I am after something cheap to keep me sane until I can get back to the track.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
