benm - there is a video of a mines GTR going around the track driven by jap drivers going "holly shittt this is fast" "too fast"
the response on it is crazy... That car has a lightweight drivetrain...
ie light wheels, light flywheel, carbon propshaft etc.. anything in the drive train lightened to help increase response
i also remember sydneykid and someone else talking about the benifits of lightening certain parts of your drivetrain, and what benifit each has - its in here somewhere :P
Roy.
by more "Race" I mean that when you change gears, the revs drop quicker, and whe you get on the gas, there isn't any surge from the engine which previously had to slow to match the road speed.
It's a bit hard to understand, but it does sound much cooler.
FURTHER REPORT
In wet weather, once the car breaks traction, the revs rise heaps faster, so you have to be a little bit more alert; but they also drop quicker, so removing your foot from the pedal stops the qheels spinning heaps quicker also.
BASS OUT
I dont think you can see much of a difference if you could lighten up the auto flywheel. The auto flywheels arent like manuals since theyre just mounting points for the torque convertor and ring gear. The torque convertor by itself is very heavy and on top of that its filled with ALOT of fluid.
One problem with the flywheel is it is only around 8mm thick at the clutch face so it overheats very fast so be careful what you use your car for.
Do you know whether certain materials are better than others in this regard? i.e. Chrome-molly, Billet Steel etc?
Adrian
Adrian
A single billet flywheel is going to be very strong and not significantly effected by heat vs it's strength. A multi material flywheel like the one shown might have issues with different expansion rates but, the few race aluminium ones that I have seen never had a problem.
The chromemolly ogura 4.8kg is 400% stronger than the factory cast iron one.
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
