I suspect alot of sand in your vagina.... Id recommend a shovel for removal ;)
As the "whoopdedoo suggests, My care (loss of sleep" factor is very low indeed, I am not promoting this product at all. As the thread title says, it looks promising given the results in other makes using this oil pump design, namely the yota J engines.
I would never ever trust billet gears.
After researching and buying a set of them (reimax) and seeing how much rediculous amount of clearance there was to the crank collar I onsold them and bought a Nitto collar and pump.
The spool gears are utter shit with poor design flaws.
Which brand crank collar Daniel? I bought an Aussie supplied collar (brand witheld for defamation avoidance!) and the clearance to the Reimax gears was huge! When I say huge I'm talking 9-10 thou! I contacted the seller and was told it "matches manufacturers specs" which was a load of shit. It was a lot smaller in diameter when measured across the drive faces and the overall diameter. I ordered a Jun collar to try and it was perfect. Clearance was around 3 or 4 thou from memory.
The Reimax gears are fine from my experience, it's the collars that can vary.
Odd question. Not completely on topic but related...
I have a Tomei oil pump and stroker kit. The machinist didn't clearance a collar. Should there be something done or would have they extended the collar on the tomei crank perfectly? Parts weren't sold together
You would hope that Tomei would be working off the fact that a Tomei pump would perfectly suited to a Tomei pump but it's very possibly not!
It's definately something that needs to be checked. The machinist should have asked for your oil pump or at very least the inner gear so they could check the clearance onto the crank. Not that there's much you can do about it if it's out of whack other than weld up the crank and resize it or grind the snout off and fit a collar.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
