  • Replies 232
Rather than a full on Db comp, couldn't we show up all these other wanna be shows by having a TRUE sound off.
Where the winner is judged on sound quality, install qulity, use and layout of components etc, instead of just who squeezes the most shit in and can make one note the loudest.
We are Skyline drivers after all, not excel drivers!
Marc, as in me? lol :D I don't have any industry experience or anything so I don't know how good I'd be at judging, but I'm more than happy to give a layman's opinion on quality of sound, installation etc. I might be able to get Chris Rogers (from Sound Off) to come for a wander if you're interested though, to add to the professional judging.
True - maybe extra points for self-installed systems or something? Dunno. Fwiw I'm more impressed by a system that has not had bucketloads of money thrown at it, but still sounds good, regardless of what it looks like (to an extent of course). Kind of an anti "chequebook competitor" stance :cheers:
The trouble with having a "install comp" style of judging means whoever paid a car sound place the most money wins.
Not necessarily, I've seen mega dollar systems that have very a poor finish and sound like shit.
And I've seen simple backyard jobs that are very neat and tidy and sound good for the money.
But I know what you mean, I think normally there is an Expert and an Amateur Class, with different Total RMS classes.
eg
Amateur
1-200 Watt
200 - 500 Watt
500 Watt +
Expert
1-200 Watt
200 - 500 Watt
500 Watt +
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
