mick51 and I are in Enoggera   We could arrange a meet point for any Northside people to get together and go down as a group
Yea sounds good, pick somewhere thats obvious to anyone though..as us Noosa folk have no idea where we're going :D
  • Replies 232
Hows This?
11:00 at Aspley Maccas
to
11:20 at Shell Nudgee
to
11:40 at Mr Pies
Leave Mr Pies at 12:00 SHARP?
yea ok that sounds like the plan! Ill be at Aspley maccas at 11 sharp (I hope) so yas better show up or I'll have no way to get anywhere :)
Sounds like a plan.....are you dodging on and off the Gateway or just hit the Gateway from Nudgie....Where is Mr Pies?? sounds like lunch??
Hey 51jay Mr Pies is at Cannon Hill Shopping center corner wynum & creek roads :) sorta out the front of the "Macro Super store"
yeah its the OLD McDonalds, infront of "Macro" and next to Hungry Jacks.
Yes come off the Gateway into Shell Nudgee and Mr Pies.
Bring UHF's!!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
