Hi Guys,
Up forsale are a set of Enkei RPF1's in 18x9.5+15, no tyres.
I've had these wheels on the car for about 2 years and absolutley love them.
Wheel condition is good but could do with a re-coat. Bought them silver and had them powdercoated black. There is no scratches on the wheels but 1 or 2 paint chips. If they don't sell i'll just have them recoated and keep them.
Here are some pics on the car:
Located in Sydney and can ship at the buyers expense.
Price: $1100 ONO
  • Like 1
https://www.sau.com.au/forums/topic/432743-enkei-rpf1-18x9515-wheels/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
