I was merely speculating based on the photos, due to the nature of the failure, it looks as though the ring gear has separated from the flywheel. But it certainly looks as though your flywheel is a single solid piece flywheel.
Lol and i was supporting that speculation ;) hehe
I just posted the other info as i feel JB clutches get hammered on here by a select few and it is based on an issue that had more to the story too (So i am told)...
Ah i see now how this thread is.
I believe the problem here in is the fact that op wants to run a unsprung clutch which I highlighted before will much gearboxes. something has to give and if the clutch cant ant the tyres dont, then bye bye driveline
I spoke to jez about it as well who btw doesn't have an issue with unsprung but provided it will hold 450kw id go with sprung centre but will need further discussion with jb although jez said in his opinion solid centers are stronger, anyway I really appreciate everyone's input, australia is a democracy and so is sau and its what makes it great on both counts
34 g Tt you run a jb clutch I hear? Which one if so and how is it?
Scott
Yes, I have the carbotic button clutch as you can see in the link to my build thread, it has the special solid flywheel and the really heavy pressure plate too! Its damn good to drive on the street as you can nearly drive it like a normal clutch once you get used to it, and its been holding up to 360-390kw for over a year and it has not had an easy life....
Jim will run you through the advantage of sprung and unsprung, from memory the main difference was the transfer of driveline noise etc not so much the harshness... Anyway, pick his brains and tell him i said hi! haha
  • Like 1
and the difference between that and the NPC 10 inch carbotic with flywheel that i have is? Got any pics of it? How much was it?
ask alot of questions dont I :P
Apparently the difference is mine will explode and destroy everything in a 100 mile radius according to gossip on here :no:
Have a look at the link on the last page and you will see pics mate! :action-smiley-069:
lol...still didnt say how much it was
Dont remember... I think the clutch rebuild was around $1000 or something but then i decided to buy the heavier cover and flywheel so there was more too it! It came with gearbox seal, rear main seal and bearing etc etc so it was the whole deal!
can you give me a rough date you did it so I dont have to scroll your whole build thread for pics..?
There was a link to the page? It was back on 22 or something... Or look on Bookface ya nutta haha
GeeTeeTee. It's mostly first hand accounts not gossip.
And when you come off the clutch hard and everything gets too much for the drive line, I'm tipping you lose traction. Don't you reckon the clutch has a lot more to hold when you have 4 wheels making that traction.
They might be fine in your application, but that doesn't mean they're right for all.
Fair enough, but if you are coming off the clutch hard then its driver error? Wouldnt you be loading it up then slipping it to a degree so you do not smash your driveline? My clutch is actually a 33GTR clutch so it would suit your application anyway, just different driving style.
Jim Berry is quite good in terms of understanding your specific needs and purpose and building the clutch around that to suit! Pretty sure PJ is hooking his up pretty hard!
close page 21... :P
its a nice looking clutch...tricstar has a good point there though
Lol close enough is good enough to me :P And yes the point is valid.
Yep GTT. Agree with your points too, but on the strip and track it's hard to always do the nice soft engagement ( in the heat of the moment ).
Clutch selection is tuff, I've had singles, twins, triples, carbonic, carbon, puck, button, sprung centre, solid centre, and all have their pros and cons.
Yep and when choosing one you need to pick for your own application not just get a clutch as it says 1000hp rated lol
But it sounds like you are pretty familiar with all kinds which is good, also good to see you mention all have pros and cons, there is always some sacrifice when you start pushing the boundaries of performance products, i say mine is nice to drive but thats not to say it doesnt shit me in Sydney traffic once its hot etc... But for my application its good, once i get some decent tyres and get it down the drags we will see how it holds up with my rookie driving!
Well my clutch is on its way! Jim looked after me alot with price which was good of him , soon as its in I will get it tuned to its potential and head to drags hopefully with no explosions lol. Then fingers crossed I get banned for running sub 11 then no need to worry just cruises and hill climbs etc. I'm thinking if switching back to street tyres instead of semis to make an easier weak point in driveline but will keep u all posted
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
