First checkout the link below for proof I can be trusted to post as I'm an ebay POWER SELLER:
http://feedback.ebay.com.au/ws/eBayISAPI.dll?ViewFeedback2&userid=iphone.addiction&ftab=FeedbackAsSeller
I'm willing to negotiate if your taking multiple items:
Apexi PFC + Manual (for R32 & R33 GTR) $700
Blitz i-Color SBC Dual Solenoid $600 (Only USED for a couple of months, before uninstalling for storage almost 3 years ago)
AEM 8 Channel CDI Module $400
1996 R33 GTR Turbos done less than 100,000kms $400
JVC stereo RRP was $2700+ $350
Datalogit USED less than 10 times $320
pexi RSM Limited Edition + G-Sensor $250
TR 485cc Injectors x 6 $250
pexi FC Commander FCC3 new Style Multi-version 415-X001 $240
Innovate XD-16 (Gauge Kit) USED less than 10 times RRP$265+ (or take it with the LC-1 for $300 RRP$360+) $185
GTR ECU $180
Apexi 3 Bar Pressure Sensor 499-X001 NEW $160
Apexi 3 Bar Pressure Sensor 499-X001 USED less than 10 times $130
R32 GTR Main Gauge Set $150
Innovate LC1 (Wideband Kit) USED less than 10 times RRP$200+ (or take it with the XD-16 for $300 RRP$360+) $140
AEM PLX EGT (Exhuast Gas Temp Sensor Kit + Adapter for O2 bung) USED less than 10 times RRP$155+ $115
Nismo Front Strut Brace $120
R32 GTR Rear Spoiler $120
R32 GTR 3 Gauge set $120
Apexi Boost Solenoid 499-X003 for AVC-R or PFC $100
GTR AFM done less than 100,000kms $110 (*EACH)
R32 N1 Bonnet Lip (Preped & Ready for Paint) $100
GTR Coil Packs x 6 done less than 100,000kms $100
R32 GTR Climate Control $90
Sard Fuel Pressure Reg $90
Apexi Power Intake Dual Funnel Universal 75mm Air Cleaner NEW $80 (Each)
Stainless Steel Decat pipe 3" (with O2 bung & plug) + 2 NEW Gaskets $80
Hicas Lock Bar NEW $80
Alternator $80
Blitz DTT Turbo Timer (displays boost can be set on Auto using boost/vac or time) $55
Blitz FATT Turbo Timer $45
22x Narrow / Light-Weight Wheel Nuts + Tool for Thread 1.25 x 12 $55
Apexi Boost Pressure Sensor 499-X002 for AVC-R $50
HKS Turbo Timer with NT-1 Harness (vehicles suited are listed after the harnesses below $50
R32 GTR Ash Tray $50
R32 GTR N1 bonnet lip Needs Attention $40
R32 GTR Fuel Rail painted RED $40
R32 GTR Full Set of Blue LED's for Gauges $30
Fuel Pressure Gauge $25
Apexi Boost Pressure Sensor Harness NEW or USED $15
Turbo Timer Harness NT-1 for BNR/HCR/HNR32 S/PS/RS/RPS13, A31, RNN14, VNW30(95/8-On), C23(95/8-On) $20
Jack NEW $20
Rim Spacers 5mm $20
Cheap & Nasty Boost Gauge NEW $15
R32 GTR Headlight Relay $10
YOU MUST CONTACT ME BY PM OR EMAIL
Pick up from Wyndham Vale VIC (sometimes Dover Heights NSW)
Or
Postage with Tracking $20 or with Signature $23
Contact Brett at [email protected]
KD-AV7008 wiring diagram.pdf
Edited by Sydneyactionman
  • Like 2
pic/model of jvc stereo?
I had already attached a PDF that gives details of the model! Here are some photos!
As per the photo the original price from JB hifi was $2599 but it sold for up to $3K in other places!
NEW PRICES & WHATS LEFT:
Apexi PFC (for R32 & R33 GTR) $700
Blitz i-Color SBC Dual Solenoid $580 (Only USED for a couple of months, before uninstalling.)
1996 R33 GTR Turbos done less than 100,000kms $330.
JVC stereo $350 (RRP was $2700+)
Datalogit USED less than 10 times $300
Apexi RSM Limited Edition + G-Sensor $250
GTR 485cc Injectors x 6 $210
Apexi FC Commander FCC3 new Style Multi-version 415-X001 $230
Innovate XD-16 (Gauge Kit) USED less than 10 times RRP$265+ (or take it with the LC-1 for $300 RRP$360+) $180
GTR ECU $160
Apexi 3 Bar Pressure Sensor 499-X001 NEW $150
Innovate LC1 (Wide-band Kit) USED less than 10 times RRP$200+ (or take it with the XD-16 for $300 RRP$360+) $130
AEM PLX EGT (Exhaust Gas Temp Sensor Kit + Adapter for O2 bung) USED less than 10 times RRP$155+ $110
R32 Nismo Front Strut Brace $120
R32 GTR Rear Spoiler $110
R32 GTR 3 Gauge set $100
GTR AFM done less than 100,000kms $100 (EACH)
R32 N1 Bonnet Lip (Prepped & Ready for Paint) $90
GTR Coil Packs x 6 done less than 100,000kms $90
Sard Fuel Pressure Reg (Cost me $200, it's NOT a $50 knock off) $80
Apexi Power Intake Dual Funnel Universal 75mm Air Cleaner NEW $70 (Each)
Alternator $80
22x Narrow / Light-Weight Wheel Nuts + Tool for Thread 1.25 x 12 $50
Jack NEW $20
Rim Spacers 5mm $20
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
