Yes. Due to the pointy nose of the 32 it tends to hit on the bonnet. You'll need to either raise your bonnet (or hack it), lower the subframe, leave off the cam gear cover (I think??) or a combination of those.
Don't let that put you off. There should be a fair bit of info on the issues in RB30 conversion thread.
Hi guys, the last 30/26 I was purchasing fell through... I'm looking at another now but it is in a 33gtst (rwd). What will I need to do to it to get it into my 32gtr. Will it just be a sump adapter? Thanks, Jonathan.
There is a fair bit of work fitting the sump adapter - drilling and tapping and grinding. A couple of bell housing boltholes will not line up and you have the choice of welding up the old ones and drilling and tapping new ones or just leaving them out.
dont leave the bolts out.
unless you weld the sump on, the extra height is going to cause the gearbox bolts to be out.
DONT WELD THE SUMP ON.
the extra deck height is a problem.
elongate the engine mount bracket holes, and drop the engine closer to the subframe.
if using a small turbo or low mounts, you should be able to get away with trimming the bracing from under the bonnet.
I have personally spaced the subframe.
mainly because I didnt want to touch my bonnet.
keep in mind, if you go this route, the cooling fan will no longer line up.
but, the guard to plenum pipe should.
Dont forget if your running a aftermarket plenum that it may hit the clutch booster.
I had fun with that one today, ended up converting a S14 clutch master to bolt straight on without a booster, built a adapter so i would not have to redrill the firewall......
Ok cool, valuable advice. Cheers!
Also, I have a guarage 101 extended sump (rb26) with a pickup. Will this pickup work on the 30 bottom end?
No, you'll still need to get the pickup modified or it will sit 10mm too high in the sump. The adapter spaces the sump down 10mm regardless of what sump you use.
Ah bugger, ok I'll have to look into that in more detail. Cheers
Yeh I'm going to be running a stock plenum so that will not be an issue.
does the extended sump use a standard pick up?
if so, just use the modded pick up.
if not, will have to be custom made/modified.
I didnt ;)
one more advantage to the spacers.
I have to get a thread up and happening.
R32 GTR with a 26/30 and with a Greddy Plenum and the original throttle bodies?
How much room was left?
Where are the closest points and distances?
Im also going to run the spacers but didnt think it was enough to clear the Clutch master.
Still not too late to drop the original master and booster in.....
yes, genuine greddy.
original throttles and sandwich.
plenty of room.
but, if using spacers, can no longer run stock fan.
have to go thermo.
  • Like 1
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
