Doctors don't have test capabilities to know for sure but depending on one's symptoms they often prescribe serotonin reuptake inhibitors.
Side effects can include lowered libido, slower metabolism, quality of sleep circadian rhythms and gastrointestinal upsets.
Brands include Lexapro, Zoloft, Prozac, Luvox, Lovan, Aropax, Cipramil and the cheaper Alphapharm equivalents.
To get off them requires a bit of supplement > neurotransmitter juggling/testing.
Juxtaposed assistance can include a pet dog/parakeet, consistent exercise, omega 3 fish oil, Inositol, quitting sweets/alcohol/recreational drugs and inhaling (in confined spaces) paints, thinners and varnishes.
The other prescription drug you're on Genelle is a tricyclic type. They've been around since the early 70s when I was first registered. If required the doctors opt for a quadcyclic like Avanza (taken at night) due to its soporific effects. They're used to diminish depressive symptoms.
STOP TRYING TO GET MY FRIENDS ON DRUGS!!!! :P He isn't the only one you reccomended them to either lol
I've been on anti-depressants benzo and alprozam for the past 13 years now for Panic Attacks, Agoraphobia and OCD, to be honest I wish I never started them, I think that they have made me better in one way but worse in many others, I'm struggling to get off them they are so dependent, I never have energy and the have actually made me depressed and emotional, nothing could upset me before I started them but now I'm like a chick with pms, all in all try everything else first before you turn to them, St Johns Wort work awesome but I cant take them due to the presciption drugs, I'm trying to wean off the prescriptions and get back on the St Johns Wort.
It was a hard trot but I managed to wean off after about 10 years on assorted meds, had some really fecking bad times in there but been off them (none in the house completely off them) for about 6 months now and only the minor hiccup when I am in a position where I feel like there is a lot of pressure on me and my stress levels go through the roof... Some days are harder than others but when I find myself in a position where I am not feeling 100% I talk to someone, even if it's to distract me until I calm down or ask their opinion on whatever my current trigger is.
It came down to trying a range of supplements and 'natural' rememedies however all in all the best solution seemed to be having a string network of good friends, keeping myself busy and just trying to maintain a level of positivity. It was tough hut it also snowballed. There are dark patches and I just force myself through it.
^This... I cannot agree more with this... Seriously some of the people I met after a massive down of mine have helped me no end without even knowing it, most of them still don't know what they have done for me!
I can't recommend Terry enough had my first consultation with him today and I found it great and really helpful, the detail he goes into is wonderful and doesn't leave you there wondering what the hell he meant as the majority of people I have seen for help from doctors to counselors you name it, just had my first dose of treatment and can't wait to see the results, I will keep you guys posted, thank you very much Terry.
  • Like 1
You're very brave Dan to have spoken up like this on an open forum. I'm very proud of you (since it's unsolicited).
A bit of waiting time is required now.
Less of a dietary change than I thought is in order - although one item might need to be monitored.
This thread might end up like an RPAH show eh? But definitely not a circus.
Thanks for starting off with strong motivation - and from your school history let's hope you've got a bright future ahead!
  • Like 1
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
