My R32 is down on power over the entire rev range but mainly down low, it feels very doughy and laggy even though it builds boost very quickly, perhaps even quicker than normal like it is running on the cold start map (retarded timing)
My car is an r32 skyline with rb25det neo with r33 intake and ancilleries, highflow (gt2871r spec), 740cc injectors, r32 rb20det ECU with nistune, z32 AFM and upgraded fuel pump making 260rwkw, it still feels fast on full boost but not as fast as it should be, down low it feels like an rb20, laggy and gutless. Overall it still runs well, eg idle feels fine and it doesn't miss or run rough, it doesn't have flat spots or feel like I've blown a headgasket or rings, it generally feels like it just has had heaps of timing taken out of it.
I first thought it was the knock sensors so I checked ECU talk and it said no error codes, to be 100% I unplugged the knock sensor and it ran much slower again proving it wasn't the knock maps.
The next thing I thought was the VCT solenoid was stuck even though I could still hear it clicking in the engine bay, so I unplugged my boost controller (controls the VCT) and it got even slower again ruling this out.
One thing I can think of is the fuel pump isn't giving enough fuel (still on stock wiring with 8/14v switchover) however it is still down on power when on full boost which imo makes me think it isn't this and it has been fine for the last 2 years.
One other is perhaps the coolant temp sender is shagged, what would this show as in ECU talk, is it the analog temp sender eg I would see 0c from this sensor, or is it a digital on off sender that shows as something else?
Finally the only other thing I can think of is there is a boost leak, though my vac looks healthy at idle and there aren't clouds of black smoke behind the car.
Other than taking it to my tuner and sticking a probe up its ass to see if it is running excessive rich or down on timing what else could cause these problems?
Cheers :)
Edited by Rolls
  • Replies 51
It's an extensive list Rolls, it could be so many parts causing power to drop. I would start with checking the cat isn't blocked, and pressure testing the intake for leaks. Work your way through the free diagnosis and only replace parts once you know they are faulty, or it will cost you plenty. Check the condition of the plugs too.
One thing that does come to mind, the wastegate may need some more preload, usually 5mm is perfect. You can simply stick a few washers under the actuator.
Scotty it feels slow even on full boost at 3k so I doubt the wastegate is the issue. Things that I think are next on the list are fuel filter, pressure test intake, drop exhaust.
It isn't pinging though so fuel filter/pump I feel are unlikely.
Edited by Rolls
if it feels like its had heaps of timing out, could it be a CAS issue...
I thought about this but does it ever actually happen in the way I am seeing? I thought if it was an issue it would cause pinging (advanced timing) / loss of power (retarded timing) in the high revs where its effect is worse, not the opposite which I am seeing eg low power down low but up top ok.
Edited by Rolls
What fuel are you using Rolls? I ask because I've been generally a bit disatisifed with my Neo too the last couple of weeks. I would suggest that the mix coming from the refinery has changed lately (winter into summer)and would be tempted to put down some or all of my car's lack of sparkle to that. I'm not trying to tell you that there's nothing wrong with your car, but given that we both driving around the same place in basically the same car....it's a possibility.
Definitely check ECU coolant temp sensor (the 2 wire one) and definitely check fuel system (despite lack of ping).
I have had cars drop a pump or reg and not ping, but lost lots of power everywhere. Like you noted, with a blocked filter I encountered mega ping/hesitation, but I still wouldn't rule it out entirely.
These are definitely your first point of call.
With the temp sender what does it do when at temp, ground the voltage coming to it? Or is it a resistive element giving an analog temperature? What would be the best way to check it? I'll check all of my filters tomorrow and also fill up with a full tank of fuel.
edit: I guess the CAS could have just shifted, I'll see if it is tight.
Edited by Rolls
Rolls, the coolant temp sensor is a resistor. Varies with temperature.
Easy to check. The temp vs resistance relationship is google-able. Then all you have to do is measure the resistance when the sensor is at a known cold temperature and at a known hot temperature (take it out and put it in hot water with a thermometer) to see if it is on spec or not.
mine broke the bracket...no idea how, but it was very sluggish coming onto boost..pretty rare thing to happen i imagine..
https://dl.dropboxusercontent.com/u/1428435/revs.xlsx
here is a datalog I did, runnign around 35 degrees timing at ~2000 rpm full throttle about to come on boost. at 3-4.5k full boost running about 27 degrees then drops to 19-20 when on full torque.
Do these numbers sound abotu right? Full boost isn't until around 4k in 2nd gear.
Coolant temp sensor seems right reading about 60 degrees as I only just warmed the car up.
My speedo cable is broken so speed was wrong
Edited by Rolls
it looks a little low to me, I would have thought it should be around 25 degs, but without knowing what the timing map looks like I can't be sure.
One of the tuner around here will have more insight than my noob opinion.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
