Count me in. Sorry I didn't make it to the QR Happy Laps, had a big night the night before. I had already paid though so didn't think it would be a problem not showing up.
Lol! The number one reason I can't make things in the morning :P
Lol I wasn't going to stay out either. Just kept saying alright one more drink then I'll leave. Got to 4 a.m. and was just like alright, I think I'm definitely not going to Happy Laps :(
Anyway, keen as for Lakeside. Been looking forward to this for many months. Won't be going out the night before either!
  • 3 weeks later...
I have attended a Torque time happy laps at QR,
and am doing the downshift one this weekend,
does that mean I am eligible ?
If so will the sound restriction be in place?
if all thats ok you can definitely count me in.
11. Members must have completed at least ONE QR Happy Laps before participating in a Lakeside session. (If you have done other Lakeside events before you may be eligible. PM me to clarify)
That rules me out. Looking forward to doing one of these happy lap things as I am a virgin to a track besides go karts.
Our next session will be at QR so you can come to that one and get some experience in your car.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
