if its at the ANU, there shouldn't be any cop trouble... mates was at parliament house.... I think that had something to do with the cops..
I love the guy with the impala!! he was having a little play with his hydraulics' stoped the cop from noticing me spinning into second leaving....
Edited by ..::R33GTS-T::..
Didnt you just pass rego at Dickson?
What are you worried about?
Im going. They cant do me for anything that easy. Maybe too loud, but i have 2 mufflers that are quiet so i can clear that easy.
My non ADR mods are well hidden.
The day I passed rego I put everything aftermarket back on. Exhaust and height are my 2 main issues - everything else is legal. I cannot afford to be defected.
hey mik, hows the rb sound with a cannon? want a louder better sounding option :)
I like it, but people can hear you coming 5 minutes away, and on the highway it gradually deafens you with the drone.
Personal taste.
Since there are so many people pulling out, can everyone planning on going please give me a definite answer whether they are coming or not.
Yes im still in.
Edited by D.I.Y. Mik
Personal taste.
Yes im still in.
how much is a cannon itself?? I can weld a flange on it to connect it to the pipe on it ..€
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
