Updated
  • New Harmonic Balancer - ATI (Super Damper), - 500HP - $400
  • New OEM Injector Ballast Resistor - $100
  • New Dspeed smoked indicators - $300
  • Near New BM57 (ABS) - $300 (couple of hundred KM's)
  • New SRI Front Upper adjustable control arms - $175
  • NEW Trust style rear pods - $150
Used parts in good working order and condition
  • Denso 720 Injectors - $350
  • Steering Rack - $100
  • Power Steering pump - $100
  • Starter motor - $100
  • Front Seat belts vgc - $150
  • Cusco Strut Brace (round) - $50
  • 5Zigen JASMA exhaust muffler - oval (axle back) $175. As new.
  • Professional Custom made Exhaust true 3" cat back with Mid muffler & Oval tail muffler (mandrel bends etc..) under 1000kms no damage - $450
  • HID's for N1 headlights with globes & ballasts - $100. Fitted and used for a few weeks.
  • Gizzmo Pencil Shift light - $50
Can't PM you as it says your profile cannot use the messaging system.
Send me a PM RE: Nismo keys, I have an offer for you.
Jimmy
Updated
  • New Dspeed smoked indicators - $250
  • Near New BM57 (ABS) - $250 (couple of hundred KM's, wasn't my braking issue)
  • New SRI Front Upper adjustable control arms - $150
  • Front Seat belts vgc - $100
Edited by Sinista32
  • 2 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
