Let us know your thoughts on the dog box after you have a drive with one Piggaz. I'm going to be in the same boat as you and am not sure about driving with one on the street.
CHeers
Edited by Chris32R
ppg straight cut dogbox would be epic.
Would be, but still being a road car I want a helical 5th for freeway use so it'll be helical
dogs.
CHeers
Will do. Either way, decision is made so ill just have to learn.
What's your setup?
They are easy on the street. To be honest, they do take a week or two to adjust to the new style of changing gear and the change in speeds you get in each gear. If i push mine to 8000rpm my speedo just nudges 100kph in first gear! Power levels, final drives and tyre size do affect this. .
Once you get the hang of no clutch, you will never want to go back a synchro box. You realise they are purely for comfort and that is it!
Can you downshift easily with no clutch while braking or do you have to use the clutch? I suppose the latter because the box would be loaded up under braking?
Also, how does power level affect RPM/speed ratio in any way? - Unless of course your clutch is slipping!
No, you can down shift without the clutch if you heel toe correctly and match the revs. The slight blip of the throttle counteracts the deceleration force to unload the dogs to allow it come out of gear. As you go through neutral, the throttle blip will speed up the gearbox internals to the same speed to allow them to engage without clunking, banging or simply not going in.
The way a dog box work vs a synchro is very different.
Power affects it slightly. More power means more force. More force means more output. More output means more speed.
For example, at one power level i got 10kph/1000rpm in 1st gear. After adding 100awkw and changing nothing else, i get just over 12kph/1000rpm in 1st gear now. So it isnt a huge factor in terms of how it affects your speed. tyre size and final drive would make more noticeable differences.
Cool that makes sense. So to downshift without the clutch you would be braking into the corner, jab and hold the throttle with your heel and then swiftly put it into the next gear?
I understand the difference between how they work, just wondering what driving styles work and don't work.
I believe you can drive a dog box like a synchro box, ie) clutched shifts etc. but you must be affirmative with the gear changes. (See PPG how to drive a dogbox video)
However, you obviously can't drive a synchro box like a dog box, as the synchros won't let the shifter slam between gears without being rev matched.
I still disagree with your statement that more power = more speed unless you have some technical description.
Everything is meshed in a manual box, so assuming there is no slippage the crankshaft speed is locked to the wheel speed.
Wheel rotations per minute is always going to be equal to something like =
RPM x clutch slippage factor / gear ratio / final drive ratio
There is no way I can see that more power can produce a higher wheel rotational speed at a given RPM.
Additionally, you are not using any more power to maintain 10k/1000rpm now than you did before, the amount of power used would be exactly the same, but the throttle position might be different to maintain the same speed.
Edited by Jazzadub
Straight cut dog box will be annoying on a street car - unless you love the loud sound of the whining gears. Not sure how loud the whine is on the straight cut PPG, but the Trust straight cut dog box is very loud. Doesn't help if you have a quiet exhaust either. Let me know when you meet up to test drive the PPG (if you haven't already) as I would like to compare and might swap to a PPG and leave the Trust to the race car.
Charlie, unless you want straight cut 1-5 (straight cut 5th would get annoying on the freeway), PPG only do a helical 1-4 helical dog with a synchro 5th (standard ratio if you wish).
I still haven't met up with Sime, is the helical dog something you're interested in?
Unfortunately, I don't think the helical will handle what I have to throw at it. The straight cut box will end up costing close to what an OS Giken sequential will (Well, close enough to make the OS Giken Seq. a viable option) The OS G is also helical cut and can handle 1500hp.
Unless you need dog 5th, helical dog 1st-4th is the best for the street because it doesn't make any noise.
After the first couple of months hating life that you just blew a shit load of money on something noisy you can't drive, come and talk to me once that's over and let me hear how you'll never want a synchro box again. Ever.
They are the ultimate.
That's what I keep hearing!
What's in yours, Paul? 1-4 helical or 1-5 straight cut? I've seen a few of your vids, particularly at Coota. You're not nice to them at all!
Helical dog 1-4. I broke a selector after over 30,000k's, and replaced a few bits from it last year, that was 6 years worth of abuse that you've seen on those videos. It's the only way the car gets driven, and I might add that both the guys who work on the car had been learning to drive on it as well.
When I broke the selector it was partially my fault, but most of the wear would have been caused during the initial period of me getting it together.
It does take time to learn though, you can't just jump in one and think you're Fangio, it will bite you in the arse and if you are offered a test drive, you're wasting your time unless someone experienced is in the driver seat.
That's decent!!
What have you done for a 5th gear? Still the standard unit? How often are you up 5th? I'm a bit frightened to bust it.
It's stock, I used to worry about busting it but I did the Snowy Mountains 1000 and had 5 passes into 5th, certainly reminds you how much you hate synchros when you go to shift in 5th fast.
  • 2 months later...
After months and months of research, I've decided to go the OS88. Went for a drive in one and it was awesome. Quiet in gear, bit of clunking between gears but who cares about that, 4 choices of ratios and 6 speed. It also bolts straight into a R33 GTR so no shaft/transfer case changes.
It won't happen this year, but it'll happen. :)
Won't that be a bitch to drive on the street though?
Meh, I'll live. It's just different.
It ain't a daily, when I take it out I'm giving it a hard time.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
