I have had the 3.0 in my 34 making 400kw+ for near a year now with two trips to the drags and a trackday at EC with no issues, but I am very mechanically sympathetic
This is a debate I had with Paully for ages when he was going to go the PPG, by the time you pay for the PPG set and have it fitted and you really need to have the Billet mid plate, you are better off saving a bit more and getting the sequential, unless there is a class restriction that requires a H pattern in which case the PPG box is the one to have
The problem with the aftermarket gearsets is they still go into a casing that wasn't designed to take that much power and flexes and due to size can't run bigger diameter gears, where the OS88 has 88mm centers and is purpose built to take upto 1500hp plus you get much faster gear changes, especially with shift cut setup :D
As for legalities, There is some crap about the shifter knob has to show the shift pattern I'm sure they could get you on of they wanted to.
Piggaz that's a fair wait for the box how does it work as in how much of a deposit you have to put down to get the ball rolling for one? If you don't mind me asking how much did one cost you?
The whole lot was the deposit, have to pay up front then wait 4 months or more for it to get here :(
It's ok for me my car is still running, but poor Paully has to sit and wait :(
Hopefully not to much longer now mate, if Paully wants to post the price he can
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
