Very interesting. Wonder how a 51R/62R SPL would run on this kind of engine setup.
It needs to be done as part of the R&D, but it won't be on this engine. Perhaps something for the v3.1 engine.
Keen to see results as your capacity, turbo choice and head setup are very similar to mine.
It should lay down your 500kw 25psi estimate easily based on what I've seen with my engine so far. The 6466 is a hell of a turbo.
  • Like 1
Can you please go into more detail regarding the decision to use a "dual gasket" setup between the spacer and head? Also, I'm curious why you chose that piston skirt design and did you consider unshrouding the valves in the head?
To deal with the thermal expansion differences between the sleeve and spacer plate I felt there had to be two highly compressible gaskets. The copper gasket does not compress at all, so it is essentially just a perfectly flat sealing surface, just like the cylinder head. So this presented no issues at all with regards to sealing, from the top of the block to the bottom of the head gasket.
I am not entirely happy with having to use a silicon based sealant on top of the copper gasket to seal it to the head (threebond 1211), but this is for the most part normal practice with copper head gaskets. Alternatives being hylomar or copper spray.
As I tend to do, I have since designed a better way around this issue. The V3.1 engine when it happens will have a copper inner gasket sealing the combustion chambers, and the same type of fiberous gasket sealing coolant and oil outside the combustion chambers. The challenge is making it all stay still when it is assembled.
The piston design was handled by Nitto. I just told them the crown height I wanted and they took care of the rest. Running the oil ring over the gudgeon pin is a common method used for custom stroker pistons. The core piston forging they used is still an RB26 one.
Yes I could have opened up the chambers a little more. But also keep in mind that this is a prototype engine, and I am reluctant to modify a Tomei head in such a manner that it might become unsuitable for use on another block.
Edited by GTRNUR
The plates are machined from 6160 Alloy.
I investigated using a stock gasket as from experience it did work well on the other engine. However there are a couple of issues.
The first is that the stock gaskets are metal re-enforced. So to reliably cut the gasket firing rings out it would need to be put in a jig and then laser or waterjet cut. For the cost of doing that I have been able to have custom gaskets made that perfectly match the dowel positions and the spacer plate, with a far higher degree of accuracy than a stock gasket fits a block.
The second issue is that the compressability and recovery data for a stock gasket is not exactly published anywhere. So to produce that data myself, I torqued 3 different gaskets up between the spacer plates to 80-ft to measure the compressability. Not only were they different in compression (by about 0.05mm), they did not compress evenly due to the seals built into it. (factor in that my spacer plate does not have a compression area around the firing rings, which would otherwise stabilise gasket compression in a closed deck stock engine).
The gasket material I have used is capable of handling ludicrous pressures (80 bar+), and has published compression and recovery data. I performed compression and recovery thickness tests on the gaskets I made too, so I could predict how they will perform in an engine.
Edited by GTRNUR
any reason why you blocked off the cooling passages on the intake side?
any reason the exhaust side cooling passages aren't sealed all around by the fiber gasket?
thanks for the thread by the way. i think people underestimate how much time it takes to make a build thread.
I'm not sure what you mean by blocked cooling passages on the intake side. Simply put, they aren't.
Have a look at the spacer plate again. From its under side you can see the coolant galleries on the intake and exhaust side intersect with a coolant gallery that allows coolant around the whole top of the sleeve (minus about 3mm at the top).
Edited by GTRNUR
Ah, I see it now. still, i'm a little worried about the seal around the coolant passages.
I suppose the fact that he has "published compression and recovery" data should mean it will be fine. My first thought was that through multiple heating and compression cycles the gasket may lose some of its tension and create a leak.
What clutch is behind this?
An Exeedy Carbon D twin plate.
I still don't see your reasoning.
There is about 10mm of gasket everywhere between all coolant and oil passages. When you factor in that the gasket material is tested to 8 bar with nitrogen gas, there is no way it will ever blow a coolant leak into an oil return, or coolant to the outside world. Coolant system pressure is at most 1.4 bar, so the seal is massively over rated for the task I am asking it to perform.
Gasket compression and recovery has been measured during the trial assemblies of the engine. Target gasket compression for the spacer gaskets is achieved at a little under 2/3 of head stud final torque. The remaining tension holding the head to the block focuses all compression forces on the copper gasket and O-rings. Similar O-ring/receiver copper head gaskets have been proven to hold the head on a 1500+hp RD28/RB26 hybrids.
Consider the surface area look of the gasket that is actually compressed for form a seal, clamping pressure per square inch is higher than with a conventional closed deck engine.
In short, the seal that the whole assembly achieves far exceeds that which standard head gasket could ever hold.
I love this idea and that people are firing questions and you are on the ball and have it covered, it shows exactly how much thought and prep has gone into this.
Two thumbs up
  • Like 1
  • 1 month later...
Hi Ian,
What was the starting deck height for the RB26?
Did you also use std length SR20 Rods at 136.3mm?
Great build thread too, really enjoyable to see this work being done to a 26 for us GTR guys.
Look forward to seeing more
Best Regards
Nigel
Hi Nigel,
This engine is configured with the sleeves 20.8mm taller than the standard 24U deck height. Add 1.2mm for the head gasket.
Yes the rods are standard SR20DET length, 136.3mm.
I finally completed the engine breather setup last Saturday (after waiting 4 weeks for hose and fittings), and got to take the car for a shake down drive. All went very well except that some custom welding that was done to the radiator had a small pinhole leak.
The engine already feels very different to drive than the previous motor. It drinks a lot more fuel for any load point too. Very revvy off idle, almost like an RB26 with a stupidly light flywheel. Except that it doesn't fall on its head when you let up the clutch. It just goes.
Keeping the revs below 4000 for the next 1000kms. I'm hoping to do some k's over Christmas.
Here's a picture showing the breather line setup.
When the engine is running, the flow of gas is from the catch can, through the breather lines to the cam covers, down to the sump, out the rear turbo train, and through a baffeled expansion chamber (mounted on the side of the engine block).
From the expansion chamber, an AN16 breather line connects to a second baffelled catch can, which then connects to a venturi angled connection on the side of the intake just before the turbo. There are restrictors to limit airflow through the hoses to the cam covers.
My hopes is that this will essentially vacuum oil from the head when the engine us operating under boost, as well as pull the engine into a light vacuum in the sump.
  • Like 1
The engine already feels very different to drive than the previous motor. It drinks a lot more fuel for any load point too. Very revvy off idle, almost like an RB26 with a stupidly light flywheel. Except that it doesn't fall on its head when you let up the clutch. .
Impossible. It can't rev. Long stroke and all :P
Sounds awesome! How long until the wick gets turned up?
I'll try put a camera in the car for the next drive I do. Even keeping the revs below 4000 its a load of fun. Although I admit that I was having GTR withdrawals too. The new 575 RSR tyres are loads of fun on roundabouts. Grip, grip and more grip, and no understeer!
It could be a while till I can put the necessary K's on it. Between the road works happening everywhere in Cairns, and now that its started raining there isn't a lot of good drive opportunities in any direction. The worst example is 6 lots of traffic stops on a near by range to the tablelands.
New overpass construction and the start of the freeway style roads up here is happening too. Albeit with Cairns level quality. Bumpy as, and pot holes appearing in the new hot mix surface after 2 days of rain.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
