ok, wanted to finish the car and drive it a little before I threw this up.
have been driving for 1700kms now, with no real adverse affects**
so, welcome all to my 30mm subframe drop thread.
any questions you have, throw them in here, and I will try and answer as quickly and honestly as possible.
please keep in mind, I doubt this is legal.
these havnt been "engineered" yet.
I will try one day, but havnt had the time/money associated to do so.
I will try and include any info I can that helped/hindered myself when doing this.
the spacers I used were made by a race/rally car engineer, and calculated that the stud the mount to would snap before the shank nut.
so, here we go....
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/
1st, why did I want to space?
easy, I didn't want to cut my bonnet.
for that one, simple reason I undertook this task.
now, as many know, you don't have to cut bonnets in a 33/34, but 32s, its pretty much the only option.
some other advantages:
-if done right, exhaust should line up to near factory*.
-turbo to guard pipe should line up*.
-guard to plenum should line up*.
-looks more factory(to a degree), as the motor is still roughly the same spacing from and strut bars.
some disadvantages:
-cooling fan no longer lines up.
-slight slope to motor.
-cant lower car**.
*should has been used, as I went with a single turbo conversion, so am unsure of pipework.
I also changed to a Greddy plenum ive had on the shelf for years, waiting for the build.
**cant/shouldn't lower the car more, as due to the engine being lower, the cvs are at a lower angle already.
so, in essence, dropping the subframe 30mm, is like lowering the car the same amount.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096833
2nd, why not lower the engine on the mounts and run no cam cover, or cut bonnet bracing?
I have lowered the engine in the mounts(die grinded mount holes).
I wanted the cam cover for the fact it keeps debris out, and less attention.
And as stated, I DIDNT want to cut the bonnet in any way.
everything I have done can be reversed.
all can be put back to standard.
that's the way I wanted it.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096835
now, for process and pics.
first, the spacers themselves...
the spacer was made in 3 parts, 20mm, 5mm, 5mm totalling 30mm all up.
the reason for this was so, if the whole 30 was not needed, the height could be adjusted.
height can be 30, 25, 20, 10 and 5mm(just swapping the pieces around.
the top spacer is actually the washer for the nut.
a shank style nut was used so it would have the greatest thread contact area, whilst also locating the spacers themselves.
the extra height on the nut is just under the thickness of the subframe itself.
and all done in the box when picked up.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096856
Lower the engine? The spacer plate to convert the 2wd block to 4wd already brings the sump a CM closer to the subframe stuffing up that idea.
I think the way you did it is the best way, the more i think about it the more logical it becomes.
The best part is if running a heavy clutch, you can still use the factory booster, im not a big fan of building the left leg, prefer to build the center one instead. :P
Come on man, get some pics happening. :)
Edit, you just put them up as i posted. LOL
Edited by GTRPSI
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096858
during the install, had to lower the whole subframe evenly.
then, enlarge the holes for the shank nut.
I used a stepped drill bit.
worked very well to get to thhe size needed.
also went a little oversize as the original holes were bigger, and allowed for any differences.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096873
ok, so now installed.
keep in mind, the factory uses pinch nuts to lock them.
USE LOCTITE!!!
you don't want a subframe coming loose.
also, the steering column required extra length.
this was a temporary solution to push the car in and out.
was thinking about it for use, but the torque put on those bolts would eventually snap them.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096878
FINALY......
I do have a driveline vibration.
thoughts were it was from the tailshaft angle.
so, I used spacers and extended bolts to space the gearbox crossmember down, and the centre bearing down.
its only under power.
more noticeable in 3rd.
cant be felt at cruising speeds or loads.
could be in gearbox, as ive got a new gearbox in the car.
could also be tyres, as they literally sat in the one spot for 8 months, ad have flatspotted.
either way, id recommend spacing the gearbox xmember and centre bearing carrier.
also, the lines on the hicas pump/valve will give the 30mm needed.
so will the steer return lines.
as stated, you can no longer use the factory fan.
electric thermo fans will be required.
hope you all enjoyed the read.
again, post any questions, and ill try and answer them.
if in the Sydney area, come to one of the runs and have a look.
thanks for reading.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096968
Luke that is one filthy engine bay! Get some degreaser on that shit!
Good work though, nice write up and good piccies!
thanks mate.
and why bother cleaning the bay when its going to get dirty again? :P
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096999
Very good thread Luke, great work, should be made a sticky.
There are a few forums on the web that talk about using a single 10mm spacer, but using a 30mm one only leaves the top 8mm higher than factory, more than enough room to close the bonnet and some more for spare.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7097091
dont forget I elongated the engine mount holes, so should be same height now.
even with that, and the sump adapter, I have clearance between the sump and X member
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7097669
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
