From NZ :P
so many cars here i want....
4 to 1 ratio of cefiros to skylines from what ive seen all the way over the north island and 80% of the skylines ive seen are all 32s and 90% of them are 4 doors.
having a ball tho here... weathers been awesome and ive been staying down my nanas beach and im thinking of moving back and buying an Evo to drive around the hills and stuff.... so many nice roads to fang around in the hills and stuff
https://www.sau.com.au/forums/topic/43485-greetings/
hahaha that was the other option...
i buy an Evo 4 or 5 here and live here for a year and bring it back... or maybe a mitsi GTO TT which are rediculously cheap here... my dad had one with about 200kw at the wheels and a porsche gearbox and wheels and all the options and he got it for 16k... they sell stockish in aussie for like 30k+
https://www.sau.com.au/forums/topic/43485-greetings/#findComment-887342
well depends on what u want and where u go...
everything is JDM here...
Integra Type-Rs JDM are about 16k fr a 96 model
Legacy JDM specs are about 16999 for a 2003 model
1993 GTO TT with minor mods is about 15k - 17k
Evo4s are about 25k - 35k depending on mods
plus theres a huge amount of different types of cars here.
https://www.sau.com.au/forums/topic/43485-greetings/#findComment-887394
ahhhhh skylines are soooooo cheap in nz :)
i wouldn't touch GTOs in aus. they are expensive to buy then expensive to service. but over there... sooooo cheap, maybe different ;)
enjoy NZ, i did. lots of adventure stuff to do there. i: rockclimbed x2, abseiled x2, jetboated, surfed (or tried), sandboarded, white water rafted x 3, concrete toboganed, caved (caving), hiked, canoed and jumped off trees hanging over rivers many times. fun times. i would have bungee jumped but i was too light at the time which meant i wouldn't bounce :) i watched a fat kid bungee jump and he totally keeeeled his lower back but he sure did bounce hehe.
https://www.sau.com.au/forums/topic/43485-greetings/#findComment-887456
ouch.... the GTR Shop is just a 10 min drive from my dads house here in in trentham.... if its under 20kgs i could bring i back in my baggage :)
Thanks mate but I think we are going to claim under her insurance. Would you believe she pushed my car (which was in the garage) back about 2 feet into some shelving, pushed the front end in about 2 inches and not a scratch on the E46 BMW 3 series?!!?!!?
https://www.sau.com.au/forums/topic/43485-greetings/#findComment-887523
lol mate i wish... its still in tokyo but will be here soon as the import approval is almost complete and theyre getting it on a ship this week i think gareth said.
i need to hurry up and sort out the rest of my finances super quick... typical of me... i leave everything to the last minute but the car i was selling (the daewoo) has clapped out just before i was about to get rid of it so its delayed the funds a little to complete the process...
It wont happen over night..... but it will happen.
https://www.sau.com.au/forums/topic/43485-greetings/#findComment-891271
Dude, could u get me a CD? it's an NZ artist called Brooke Fraser. Her CD comes out here July 11, but i can't wait that long. She's like X2 Platinum/Platnium (sp?) over there, but no one knows her here (except for those that went to the John Mayer concerts, she was the support act)
Brooke Fraser - What to do with daylight
I'm gonna put my molly meldrum hat on and say this girl will be big here :cheers:
https://www.sau.com.au/forums/topic/43485-greetings/#findComment-892307
I'm gonna put my molly meldrum hat on and say this girl will be big here :)
lmao i will get my mum or a cousin to get it for u if u want and send it over...
https://www.sau.com.au/forums/topic/43485-greetings/#findComment-893547
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
