mrsr32 Posted November 22, 2013 Share Posted November 22, 2013 is it possible to replace the factory oil pressure sender with an aftermarket one or does the ecu actually use it for feedback? Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/ Share on other sites More sharing options...
Ben C34 Posted November 22, 2013 Share Posted November 22, 2013 Ecu doesn't use it. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118862 Share on other sites More sharing options...
Ben C34 Posted November 22, 2013 Share Posted November 22, 2013 And the thread is 1/8 bsp if you decide to replace it. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118897 Share on other sites More sharing options...
89CAL Posted November 22, 2013 Share Posted November 22, 2013 I think the sensor is actually NPT, I've just set up stock + aftermarket sensor on a manifold and the aftermarket sensor was NPT, and the stock sensor turned out to be the same Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118900 Share on other sites More sharing options...
Ben C34 Posted November 22, 2013 Share Posted November 22, 2013 I am 100 percent its bsp. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118917 Share on other sites More sharing options...
Ben C34 Posted November 22, 2013 Share Posted November 22, 2013 Npt is close. But not identical. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118918 Share on other sites More sharing options...
Dan_J Posted November 22, 2013 Share Posted November 22, 2013 (edited) could just run this and have both http://www.ebay.com.au/itm/like/190448345622?lpid=87 i've connected a big red pilot/(shift) light to the factory on/off pressure switch which is handy as u cant miss it when giving the car a beating Edited November 22, 2013 by Dan_J Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118953 Share on other sites More sharing options...
Ben C34 Posted November 23, 2013 Share Posted November 23, 2013 That's the obvious choice ti use a tee piece. but like I said, u need bsp npt is not the right size for the block. Alot of aftermarket stuff is npt cos that's what the yanks use, but the japanes use bsp. It is extremely close but not the same. If you have a search on here you'll find people have had issues with npt fittings. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118993 Share on other sites More sharing options...
Ben C34 Posted November 23, 2013 Share Posted November 23, 2013 And just to add, I have both bsp and npt taps, so am completely certain is bsp. The npt tap does start, but after a couple of threads binds up, the bsp tap runs in nicely. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7118999 Share on other sites More sharing options...
89CAL Posted November 23, 2013 Share Posted November 23, 2013 The block (not oil cooler housing) thread for a sensor is BSP, but the RB25 oil pressure sensors that goes into the oil cooler housing is NPT. Here is what I've done with mine: I've been through all this recently, thinking I would need to make a custom oil manifold to house both sensors. Those are 1/8NPT fittings Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7119225 Share on other sites More sharing options...
Ben C34 Posted November 23, 2013 Share Posted November 23, 2013 Put it this way. you can screw an npt fitting into a bsp. But its not right. If is working for you that's cool, theres nothing to worry about. I have checked the oil cooler hole with my taps and definitely bsp. Nissan wouldnt use 2 different threads, and I'll say it again, nothing jap will have npt threads. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7119440 Share on other sites More sharing options...
89CAL Posted November 23, 2013 Share Posted November 23, 2013 Yeah I thought the same but the two sensors seem to have the same thread. Unless it was very model specific. Didnt really make sense that the block was bsp and the cooler not but the aftermarket sensor screwed into the cooler but not the block. Strange Perhaps nissan sourced the oil cooler from an aftermarket supplier on certain models. But in the interest of not creating to much confusion here I will agree that it should be bsp Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7119455 Share on other sites More sharing options...
mrsr32 Posted November 23, 2013 Author Share Posted November 23, 2013 Thanks for the advice guys, i'll buy a tee and do that. i was going to run it into the oil sandwich plate, but i'll keep that just for oil temp. Link to comment https://www.sau.com.au/forums/topic/435374-replace-rb-oil-pressure-sender-with-aftermarket/#findComment-7119864 Share on other sites More sharing options...
