All the real drivers have taken their guards out. :P. It scrubs like a bitch when your low. My tyre actually ate through my drivers side guard. :P
You mean real posers take their guards out..... real drivers dont worry about stance, hellaflush...... :whistling:
https://www.sau.com.au/forums/topic/435410-boot-lip/page/2/#findComment-7125167
if the car is low and you have fat wheels, guards need to be taken out. If you have stance, hellaflush, you need your brains taken out :whistling:
  • Like 1
https://www.sau.com.au/forums/topic/435410-boot-lip/page/2/#findComment-7125168
Haha I had my last car "mitsubishi fto" rubbing a little but full lock would chew the tyres and the guards were takin out, just wAnt to avoid rocks and dirt getting between the panels. And it looks tidy having them in ;)
https://www.sau.com.au/forums/topic/435410-boot-lip/page/2/#findComment-7125377
Dunno GT-Rs can run 18x10.5+15 with no guards issues, looks mean and it track happy.
Z tune runs 18x9.5 +5...no guard issues
Porsches run a 315 tyre.... STOCK and looks epic... no guard mods required...... :cheers:
https://www.sau.com.au/forums/topic/435410-boot-lip/page/2/#findComment-7126476
I'm talking about the inside plastic guards. Most skylines would have them removed. Not talking about rolling guards or anything. :)
https://www.sau.com.au/forums/topic/435410-boot-lip/page/2/#findComment-7126508
I just prefer my wheels to fill the guards not sticking out or anything, hellaflush and all that shit is a bit stupid but I can appreciate the work.
looks like I'll just have to bite the bullet and pull it out aye :/ I intend on doing it by the book since I payed good money for my car and want it looking neat with a nasty bite ;)
https://www.sau.com.au/forums/topic/435410-boot-lip/page/2/#findComment-7126960
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
