One thing that could be affecting this is the "G Sensor" (this also takes a reading from ABS unit - no longer in car?)
(found under the centre console, 2 plugs disconnect/reconnect and if it's had a good thump then there will be a red indicator in the window.
Related to 4wd issue asking about earlier ?
Check all your grounding strap points too (just a precaution)
Still think you need to ask the guy you bought it from about these issues. He's bound to have knowledge as it just didn't start to play up the day you bought it.
Edit: Probably need to go from A to Z troubleshooting Attessa system.
sorry to jump in on todays few posts :blush:
Edited by Sinista32
Ok I'll have a look at those things, as for the bloke I brought it from, isn't answering or replying, if I can't figure it out I guess ill just have to take it back to his house and hope he's home, giving him benefit of the doubt he's busy this weekend. Such a shit way to start owning a gtr.....
yes - I hear you buddy.
If he's a member on here I am certain he wont leave you in the lurch !!!
be aware also there is no preload in the 32 GTR as there is in the 33/34 GTR's. So it's slow to kick in and then it's all at once.
The OEM G Sensor also has a very slow sample rate which also delays reaction in comparison
I'll check the workshop manual over the next few days and/or send you a link to download (your going to need it I think)
So should I disconnect the plugs on G sensor?? There's no red light on at the moment!
Ignition off - it wont hurt
Likely wont help either but at least you know they're firmly connected
You already checked the Attessa fluid in the boot with engine running ?
Disconnected/reconnected the Attessa ECU in the boot.
Still only the 9 error code ? no others ?
Checked the fuses for the Attessa ?
No rattle in the Attessa ecu (someone recently found a loose screw in theirs)
As I said I'll have a look at the manual later or send a link through for you.
Edit: If it was red it would stay red. It doesn't go on/off.
Edited by Sinista32
Sorry - You did check the Power Steering fluid (whilst running). ?
Just getting confused with Hicas (4WS) and Attessa (4WD) system. Attessa resevoir in the boot - doh!
Edited by Sinista32
Power steering fluid is full, but 4wd light has come back on I'm not sure if I'm clever enough to figure this out lol
Speak to the guy. See how you go
I now have the workshop Manual open on my desktop
Still trying to remember where I downloaded it from.
Section C3 is what you need. Not sure if your a DIY sort of person
If not then you could get your local JDM garage on to the job
Still I don't know if this is your issue but to me it sounds like it.
Eeeesh - best go see a good mechanic you can TRUST
You must feel like shit :(
Hopefully nothing too serious nor too expensive
Steering/suspension ?
Shit is an understatement
Yeah I guess I will have to take it to mechanic to check out, steering and suspension seem fine, but by the way my lucks going that will all probably fail soon!!
Thanks for the help mate :)
I wish the best for you mate.
It's funny that prior to buying a 2nd hand car you can always contact the owner. After you buy it the unscrupulous ones cant be contacted.
I hope that the guy you bought it from is a stand_up guy or it may be a very hard lesson learnt/paid for.
Ps. industrial paint stripper if you discover you have a need for it conveys disappointment very well to previous dodgy owners other vehicles ;)
So the guy I brought it off got back to me, says he never realised it :s but what ever!
He also informed me that it has a tomei hicas lock kit on it so maybe that has something to do with it, I don't even know what that is so will research it and see of it could be the problem.
Maybe I'll also get a new boss kit just to reduce the source of problems to choose from.
I had a look at the plug that seems fine, the guy that had it before did some research and it would appear some other people have had the same problem and it was because they didn't have genuine Nissan diff oil in it, he can't remember what oil is in it so that's my next thing to check and change tomorrow!
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
