Formula 1 is to make another attempt to ban tyre warmers in 2015.
Previous efforts to introduce a ban have been scuppered because of safety concerns, amid worries from drivers about racing on cold tyres.
But as part of a raft of changes proposed for 2015, the FIA announced on Thursday that all forms of tyre heating devices will be outlawed.
The FIA has also ratified that the minimum weight of cars will increase by 10kg to 701kg in 2015 - which should help alleviate concerns that heavier drivers are put at a disadvantage.
http://www.autosport.com/news/report.php/id/112250
idiots.. didnt pirelli state they need to be within a hot and cold temp range to not explode?
Eric Boullier is set to become McLaren's new Formula 1 team principal after quitting the Lotus team.
Following intense speculation about plans for McLaren following Ron Dennis's review of the organisation, Boullier has resigned from his position as Lotus F1 team principal with immediate effect.
The Frenchman, who has done an impressive job at Lotus despite financial constraints, is now favourite to land the job at McLaren.
Lotus has confirmed that its owner Gerard Lopez will be its new team principal for 2014, and will share responsibility for running the outfit with co-chairman Andrew Ruhan.
Although the loss of Boullier will be a blow to Lotus, the Enstone-based outfit remains hopeful that it has a strong commercial and managerial platform going forwards.
Lopez said: "Lotus F1 Team has never stood still and we head into what promises to be an exciting 2014 season with an innovative new car, new partners and a new management structure at Enstone.
"Great things have been achieved over the past years and we need to continue this momentum.
"We thank Eric for all his hard work over the past four years and we are confident we can continue to fight as one of the top teams in Formula 1 over the seasons ahead."
Lotus is missing next week's first pre-season F1 test, but plans to unveil its new E22 car at the start of the second test in Bahrain.
McLaren is launching its own 2014 challenger at 12pm GMT today (Friday), although it is unclear if it will announce any plans for Boullier.
http://www.autosport.com/news/report.php/id/112254
well f**k me i didn't see that coming..
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
