they sound like cars from a lower category :/
That's what I was getting at, but we'll have to wait and see til they're at full noise I guess...
Eric Boullier appointed Racing Director. Read the official McLaren Mercedes press release here: http://tinyurl.com/nwwhfba
they're probably not going to ever hit the redline except in qualy. An article I read ages ago suggested that the fuel flow limit and power delivery characteristics of forced induction mean 12,000rpm is more likely to be the operational ceiling rather than the mandated 15,000rpm limit. They also have significantly less engines to use this year, so lower revs seems likely.
But having heard a few more videos, I'm starting to think they sound alright anyway. Sure, they're no V10, but those days are long gone...
I'm liking the looks of the cars too. Eg Force India looked crap in photos with that big black dong out the front, but it looks pretty good on the track. At least there's variety and innovation being shown which is interesting, and to me they all look better than the stepped noses from last year. Well, maybe not the Zoidberg Lotus...
It's very unlikely I know, but there's potential for a smaller budget team to have jagged a design edge thanks to these regs.
Also hoping the William livery isn't just for testing - it looks good in blue.
I'd wait till the next test or race day before writing the new engines off. I'm sure they are not going flat out yet. There must be plenty of engine and car tuning going on there. I know the engines have probably done thousands of hours on engine dynos, but thats different to taking it out on a track.
After all they went from 1:27's on the first day to 1:24's on the second day (unless my memory has failed me :) )
Just shows you how much they were holding back day 1
Last year they were sub 1:20's, with all the aero differences I dont expect them to get near last years times, but there is probably still a bit left in them
Or maybe I'm just saying this stuff so I will convince myself I like the new sound lol
If you can hear some turbo whistle maybe it will make up for it
To be honest, sounds like the honda nsx with an exhaust at high revs (obviously without the turbo :-) )
Whilst both sight and sound play a massive part in formula 1, for me its more the fact that this is the elite level of driving and pushing limitations on engineering and producing the quickest cars going around a circuit.
So just personally speaking, sound of the engines were nice but nothing worth getting too upset about as long as they still go fast. I am sure there is a WHOLE (yes i used caps!) lot of seconds to be stripped off these laptimes as we progress throughout the season. I think "Ve Tool" even said that in a recent press release.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
