What do they sound like fags?
Watching telly, in car on Dans car sound shite, like a MotoGP bike almost, but outside of car isn't as bad...
Scrap that. Sound shit. Lol.
You can't hear them go around the track anymore. :(
Hell I can't hear them until they're right next to me...
I don't mind the sound from outside the car, some forced induction whistle is good. It is still a let down but not as bad as I was expecting.
This, they're a bit meh.
I hope they sound better when they start pushing the cars more.
