http://bleacherreport.com/articles/1927268-breaking-down-the-costs-of-racing-in-formula-1-is-spending-out-of-control
Jan 19, 2014
The 2013 Formula One season was filled with reports of teams in financial trouble. It is no secret that many of the smaller teams (and even the race-winning Lotus team) are struggling. At the same time, F1 is bringing in record levels of revenue
...Last October, according to Tom Cary of The Telegraph, CVC, "Formula One’s largest single shareholder, took a $865 million (£538 million) dividend in 2012," and that, "It is believed that CVC, who paid roughly $1 billion (£620 million) for the sport back in 2006, has now gained more than $2 billion (£1.24 billion) from the sport in the last 24 months."
The private firms that own the commercial rights are not interested in what is best for F1, other than if it can make them money. As the numbers demonstrate, they are making quite a lot right now, so, from their perspective, F1 is probably not in need of fixing.
but Bernie says the teams need to share thier bit of revenue out better so he and his mates can continue raking in half billion dollar dividends and mulit billion dollar profits unimpeded!!!
who's the wankers?
Edited by hrd-hr30
Would explain why Button was in such a foul mood during the race and post race. G.O.N.E! Been wishing it for a while but now that it appears a reality I will be a little sorry to see him go. He is a quality fella....even if he can only drive the perfect car he has rather hammered his favoured rookie.
Perhaps Honda would be wise to give Button a year swan song tour and keep the kid in testing-simulator role for another 12 months just to be sure that they have both Button and Alonso pullingmax points every weekend. (something that kid has not been great at doing) For Honda McLaren could be the difference between 3rd or 5th in the WCC next year
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
