Hey guys getting in early for power cruise next year as I missed out last year without having a car ready. Purchased this beautiful piece from a well know SAU member a few months ago and now its time to get started. At the moment we just throwing it together to get it running and have some fun so some of the mods are extreme and some not so much but all in good time everything should work together in the future :).
Mod list:
Rebuilt rb26 with forged pistons, acl bearings and head studs with a cometic head gasket
Hks T51r Kai with a spl front wheel which has now been machined ready to go by Mr Turbo in the gold coast
6boost exhaust manifold that I have to modify to fit the turbo
Turbosmart 45mm gate
OS twin plate
Accusump setup with oil cooler and oil filter relocation kit
Usual twn 044 surge tank setup
Old school M800 Motec
HKS 100mm intercooler
1600cc injectors
E85
Just going to throw boost at it see how it goes with pump e85 ;)
  • Like 2
https://www.sau.com.au/forums/topic/435549-mnpiii-r33-gtr-powercruise-project/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
