at this stage most likely an evo of some sort...
looking to downsize money in cars and put more into property, and go back to just one car, so want something fun, i can drive daily, has abit of space (4 doors), is fast and can go to the track inexpensively... evos seem to fit the bill pretty well with the price range im looking at, i know it wont be the same as the gtr though unfortunately ha.
Congrats Isaac. Probably the nicest 34 I have seen as well. Brilliant choice.
Hi Anthony this is Isaac the guy who bought your car :) yeah I'm extremely happy with it and specially how well it was looked after, been told by my mates and mechanic that it's probably the best condition 34GTR they've seen . Looking forward to catch up with some of the skyline forums members when they're going for a cruise.
Ha! Gaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaayyyy!!! lol
yea always been more into evos than sti's
haha bring it on!
:P
Will be good to get out on the track with ya man!
Hahahahaha love sti's. Engine is a bit lower down. And handles better with all assist off I find.
But this debate can go on and on. Haha
I've done a clutches, engines and timing belts in both, subaru is a lot easier in all accounts
Im talking modification wise evos are a lot easier. Subarus are shit. I once took a round about in a STi was understeering nearly climbed a kerb as with the evo at a greater speed took it like on rails.
Lol the Evo and STI battle still rages on.
One thing is clear though.
and i just cannot AGREE MORE! LOL!!!
The battle never ends - was lucky to compete in a hillclimb couple years back with a GC8 with DCCD and also had some fun with an EVO - personally i find the Sti's nicer to drive... The evos without any electronics can be a handful.. Agreed on making power on the EVO much easier...
But in the end - its personal preference - either car in good hands - bloody rapid cars...
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
