Hi
Last week I went for a short drive and floored it couple of times on high boost setting. The next day I found coolant under my car. I did not see where it came from.
I added about 1.5 liters of coolant mixture and went for a drive without revving over 4K and on a lower boost setting. I haven't lost any coolant after 100km of driving.
Do you guys know what the problem could be?
S2 RB25 ,bolt ons, Link, 300RWKW, standard internals including head gasket.
Cheers
https://www.sau.com.au/forums/topic/435587-coolant-leak-please-help/
The water temp was fine. It was just a normal drive except I went to red line on 2nd and 3rd once. Now I remember there was some coolant on the ground under overflow bottle and some under the engine (should have told you that before). Overflow bottle is almost empty now.
I just hope it is not lifting the head because of detonation or anything like that.
The car has aftermarket radiator, but no oil cooler.
I have the same kind of problem, only leaks sometimes when the car is turned off... Mine looks like around the back of the engine area as it drips from there. Also can't find where. I figure maybe it's a split in a hose that leaks under pressure...
Similar issue on my 32R.
I "modified" an existing radiator cap so i could feed pressure from my compressor. It was simply a male air house coupling hot glued/tapped into the top of a spare radiator cap. Then set to around 9PSI which allowed me to sit beneath the vehicle whilst pressurized. Dont push any more then this through though.
In my case it appears to be the seal inside of my water pump but this was only occurring at full temp and only very rarely.
Otherwise take it to a professional and have it leak tested :)
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
