Hi all,
I need to clear out a couple more items that I have been stashing away for my next build as they are simply going to waste on my shelf.
Sadly, this means I have to let go my set of Genuine Mines Super Outlet Pro Dump Pipes to suit RB26DETT.
These are about as top shelf as you could get, incredibly well made and have a nice big bellmouth design for maximum flow, with a 70mm main section and enlarged turbo outlet.
They are brand new, un-used and looking for a new home.
New price is ~$1200.00 + Post
I will let these go for $795.00 firm
Pickup available in North Sydney, or alternatively I am happy to post them at the buyers expense.
Cheers.
My N1 came with these on a complete Mine's system > 319.5awKw running on 21psi and just a fuel pump/injectors upgrade. No restriction at all & really well designed.
There's no loss of RB sound but it is a wee bit different.
Hope this helps a buyer to decide!
Seing you have a R33, I assume its the 32/33 model and wont fit 34 as it uses different MAF sensor plug diameter?
crossing my fingers its the R34 version you have, if not good luck with sale!
They suit R32/R33/R34 GTR, and you use an 02 sensor adapter plug where needed, depending on if your car uses the smaller or larger sized 02 sensor.
Now it appears that there's a new Mine's front pipe f/s too.
Both Blitz' dump pipes & Spring&Water's front pipe here in Sydney > What a pair! > What a saving!
Thanks all!
Someone give these puppies a new home before I decide to keep them.
Will entertain serious offers close to the asking price (given its $500 cheaper than buying them new already!!!!)
  • 1 month later...
Is the 02 sensor adapter plug included? Do mines include it with the product?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
