Hi guys, I'm new to the forum and don't have a car. Depending on finances I'm planning on getting an s15 next month.
My preference would be a jdm spec r but there's some aud spec s' and r's for alright prices. Any advice would be appreciated, noting that I'm planning on modding any with the following.
Exhaust, fmic, power fc, injectors, fuel pump and maybe headers.
What would be my best choice?
Thanks
https://www.sau.com.au/forums/topic/435664-interested-in-an-s15/
Chances are, a clean stock AUDM S15 will be better condition than a JDM one of equivalent mileage (not that imports have very high chance of being wound back). The AUDM ones (the standard ones) are usually owned by people who can afford to service it properly and the km are most likely genuine. Plus you get a 260 km/h speedo ;).
If the car you're looking at is modded then it gets tricky.
I own an ADM Spec S, and it is a great car. Do suspension work before you even look at power mods.
Do not even bother with JDM. The market is flooded by accident damaged examples of those (thanks to dealerships). And don't expect to find one with genuine KM's.
Go for an ADM Spec S, it is lighter than the ADM Spec R (as it doesn't have a sunroof).
You'll have much better chances of finding an ADM one that has a straight chassis and original panels.... though these chances will still be slim. Ive scanned the S15 market for a long time.
Cheers, thanks for the advice. Yeh I was planning on putting in coilovers anyway, what else suspension wise?
My eyes have definately been opened from feedback now. I wasn't aware of how many spuds are out there, I used to have a 180sx red top, first Australian owner and my mechanic said it was one of the cleanest and straightest he'd seen. Was just lucky I guess.
Yeah, very lucky haha. Straight and original early model S13's/180s are near impossible to find nowadays.
Massive improvement in front-end stability and turn-in if you install a Nismo Power Brace II or Cusco Tension Bar. Also, install front/rear strut braces. Rigidity wise this is ideal for the street.
I have HKS Hipermax III Coilovers... with 6kg Front/4kg Rear rates. They are a firm ride when the dampers are set hard. From what I've found, going with a coilover that has higher spring rates would be completely overkill for our roads, unless you like drifting. As for alignment adjustability - I have Ikeya Formula rear camber arms, front tension rods (for castor), and rear toe rods.....they really are excellent quality but there are plenty of cheaper options available.
Go with something like that for a basic suspension/rigidity setup and you'll be set. Then down the track you'd have room to install some swaybars.
if your modding who gives a f**k. just go for the bloody cheapest.
f**k panel gaps. f**k lightness, f**k it all.
buy the cheapest and spend your change on mods.
then sell it and buy a real car!
but serious. so long as it isnt rooted, just buy the cheapest bro. :yes:
A couple of good posts above about adm being generally in a lot better condition than jdm models.
I recently spent about 2 months looking for one and bought an adm model with awesome mods for a reasonable price. Saw too many busted jdm models .. My tip .. Check the chassis rails all the time lol
JDM cars have a few benefits... The JDM Spec R engine has 184kW, compared to the 147kW for the AUS spec, same as the S14 series. Better trim, with cool colours on seats and door trims, A-pillar boost gauge, better stereo, climate control, and a ball bearing turbo (i think anyway)
Personally I'd like the GT spec AUD S15, with leather, etc but good luck finding one
I am a newbie too and looking into an s15 for myself but, in saying that I want to do a lot of research too, hence why I joined a couple of forums to find out the main problems to look out for and what not so any info would be very helpful! excuse the intrusion of this thread sir :P
will follow this post for any updates :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
