A very sad day indeed. A couple lost their child, a daughter lost her father, and our scene lost one of its most influential people this side of the millennium.
For those interested: The driver of the Carrera GT was the owner of 'AE Performance', Walker was on their race team in an E92 M3 competing in the amateur Redline Time Attack series. They were leaving a charity event at the shop that Walker's organisation was holding for those affected by Typhoon Haiyan.
Also, don't know if everyone has seen it, but there's footage of a couple of guys in an E46 m3 driving past the crash while its still burning. It hits me in the gut knowing that there may someone still be alive in there.
Edited by alex182
To be honest I only ever liked the first one. The passion for cars was very evident and it was a genuine movie. They put lot of effort into it, showing the lives of true car\racing enthusiasts and we could relate to it.
Now they've become too commercialised.
They finished filming F&F 7 so it might be a bit of a sad watch when it comes out
  • Like 2
yeah, they were leaving a charity event that was being held at the workshop owned by Roger Rodas (the driver), i'm pretty sure Paul had a stake in the place as well.
Tyrese at the crash site. Hit me pretty hard
  • Like 1
TMZ reports that the crash occurred as the friends were on their way back from a 20 minute drive.
Prior to that drive, Rodas had personally taken the wheel of the vehicle after one of the former race car driver's employees at the upscale auto shop he owned was having issues backing the car up into the garage. The vehicle reportedly kept stalling for the employee.
As Rodas took control, Walker hopped in because he hadn't yet had a chance to take a spin in the impressive sports car.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
