Hello, so I bought my 1993 nissan skyline r33 gts-t from a dealer 2 weeks ago and the man guaranteed the car was in perfect condition and there was no oil leaks bla bla. Got there and there was no oil on the floor on any where that I could see. He says it just had a road worthy, by he's friend. Who had fixed a rocker cover leak that as soon as I got home it started leaking. After driving the car on day 2 the other side started leaking and I got a quote for 380 to degrease the engine and change both gaskets as the previous man had just used silicon sealant. So I ring the dealer and said you need to pay for this and he said ok but he's expecting me to take it back to he's mechanic who I think is dodgey! Apparently he's mechanic can do the job for
100 dollars, how can he fix both leaks and put in two new gaskets for that price? He's obviously just gunna use sealant again isn't he? The car is now leaking oil in 3 different spots around the rocker cover both sides. Also the dealer told me the air con needed re gasing but the mechanic I went to recently said there is nothing left of the air con in the car! What can I do about this? Also the dealer left me with an empty tank when I collected the car wasn't happy lol Thanks for the help.
It HIS mechanic not he's mechanic btw
As said above, learn to do it yourself and maybe take someone with you when you buy a car as missing aircon is not hard to spot
Well I'm new to Australia and new to skylines so had never seen air con before, or what it looks like and he actually said to me if you want me to pay for it you have to use MY mechanic.
You got scammed, a simple vehicle check would have let you know any issues with the car before purchase.
If you take it back there, they will probably shaft you worse.
Find a local mechanic and get them to look over it, and change the gaskets.
I just want to know what I can do about this, If there is some one I can speak to to get money from him to pay for it to get fixed properly. As a dealer surely he can't get away with d
The dealer is right.
He has first right to fix it I think.
Why don't you give it to him and ask to see receipts of the parts, ie, cam seals, when you collect it.
The warranty he sold you too, isn't really worth much. I hope you read the fine print.
I got text of him apologising for saying the air con is gone and that he will replace all parts but I have to pay for them to be fitted and that he's mechanic previously fixed the leak. I also have a diagnostic letter from another mechanic saying both gaskets need to be replaced. He also said he's machanic said there was no oil leaks and the engine bay was clean. If you read the add it dosent say about any problems. http://www.gumtree.com.au/s-ad/mooloolaba/cars-vans-utes/1993-nissan-skyline-r33-gt-t-coupe-coilovers-bodykit-racewheels/1031838290
So this is how it works? I have no choice but to get my car slowly ruined because I can't afford to get the work done my self? That's the only reason I got the car, because of the warranty
I would stay away from the dealer and "he's" mechanic, if at anytime you are unsure (or dont know anything about skylines)of a cars condition then get it checked BEFORE you buy, a bit late now for you tho
contact consumer affairs and discuss it with them, see what they recommend.
the dealer has first option to fix the issue, if you are polite with them they might fix it properly.
buying a skyline will always cost you money, so if you wanted something that will not be a constant expense you bought the wrong car. For that matter any 20 year old car will be the same.....
unfortunately I think you will be in for a long painful process with this dealer, so might be better to try get a refund on the warranty and go it yourself.
any car of this variety should be thoroughly checked out before purchase, even if from a dealer as they really don't know anything about it and only do a quick once over and tidy up so they can flog it off..
Mate, who puts all of the cars problems in an advert...?
Anyway, who your looking for is the Consumer affairs.. Go call them and see if they can point you in the right direction. Then maybe ACA after that, ask for Tracy.
Btw, the ad says it has Air Con, therefore you would be within your rights to ask for it. I wouldn't pay for it to be put back on...
The machanic I went to recently also said the rear main seal may be leaking aswell I really need the dealer to pay as I can't afford it, that's why I'm hoping Someone knows a way I can get them to pay for it but so I can get it fixed properly locally not by him. Obviously no one knows what I'm hoping to achieve. Thanks for the help tho
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
